Covertible back will not release
Old May 2, 2025 | 01:27 PM
Mooseham's Avatar
Mooseham
8th Gear
Default Covertible back will not release
I recently bought a 2002 convertible. The weather is getting nice and I would like to put the top down. I can undo the 2 latches at the front and when I push the yellow button behind the driver seat the windows go down.
The problem is that the back of the convertible will not top up / release so I can not open the rear hatch and put the convertible down.
Any thoughts are much appreciated.
regards,
Old May 2, 2025 | 03:48 PM
Fast one's Avatar
Fast one
Do you hear the cover solenoid try to unlatch when the button is pushed? It's inside the waterfall and part of the latch.
Old May 2, 2025 | 03:56 PM
link9a's Avatar
link9a
If the trunk open the release button will not work ,,
If the doors locked and the convertible top down it will not release the back
Check the fuse 17 and relay 41 in the passenger foot well fuse box. , check the release button itself
Old May 2, 2025 | 04:08 PM
Mooseham's Avatar
Mooseham
8th Gear
Yes, I just checked and I can definitely hear this type of sound from the waterfall when \I push the button.
Old May 2, 2025 | 04:21 PM
Mooseham's Avatar
Mooseham
8th Gear
The trunk is closed and the doors are not locked, when I bush the yellow button I can hear the solenoid in the watherfall doing what I think is trying to unlatch. I will have a look at the fuses.
Old May 2, 2025 | 04:28 PM
link9a's Avatar
link9a
While you press the button try shaking the back with you hand ..it could be the back get stuck
Old May 2, 2025 | 04:40 PM
vetteLT193's Avatar
vetteLT193
Is the problem the tonneau cover doesnt come up or are you saying the top doesnt come off the tonneau? To drop the top you lift the front and the rear of the top simultaneously. It sounds like you aren't lifting the top up in the front and back at the same time based on the description
Old May 2, 2025 | 06:10 PM
Mooseham's Avatar
Mooseham
8th Gear
Thanks all good now, Likely a combination of me not knowing what to do and some helpful hints from the site. thanks again.
Mooseham's Avatar
Mooseham
8th Gear
To Covertible back will not release
