Coolant going past thermostat when cold
Old May 2, 2025 | 06:23 PM
Diydoidothisc5's Avatar
Diydoidothisc5
Default Coolant going past thermostat when cold
Does this thermostat have a bypass hole. I put a new acdelco 12571261 thermostat on a few months ago and I was doing a full coolant flush recently to get all the old stuff out, but i was noticing i got a lot more coolant out than people said I would. I sort of figured it would be the thermostat letting coolant through. I removed the rad hose and added coolant to the upper hose and once I did that I get a mild trickle of coolant from the thermostat. My question, is the hole circled a bypass to let a small ammount of coolant through or is the thermostat likely stuck open just slightly.
Old May 3, 2025 | 01:09 AM
mmartinez's Avatar
mmartinez
Yes, thermostats allow a small amount of water to flow past them, that is normal.
Old May 3, 2025 | 06:05 PM
Lowend's Avatar
Lowend
Yep - the hole stops steam from getting trapped amongst other things
Old May 4, 2025 | 08:35 PM
Diydoidothisc5
great thanks for the info!
Diydoidothisc5
cool It was hard to believe a good quality thermostat would have failed already
Old May 5, 2025 | 03:19 PM
lucky131969's Avatar
lucky131969
Not steam.......AIR. The hole facilitates air bleeding in the system. All thermostats have this in some form as a hole, valve, or jiggle pin.
To Coolant going past thermostat when cold
