Weird power seat driver side
Old May 8, 2025 | 12:55 PM
Travy's Avatar
Travy
3rd Gear
Default Weird power seat driver side
hi all. I took my driver seat out over the winter to put in a new seat pad. No problem. Put it back together and the power controls on the side were on and drained my battery. Got a new bat under warranty. so when the lumbar buttons are in their off position they sound like they are running and when I push them to an on position the noise stops. I only touched 3 wire plugs to do the seat foam. 2 to get the seat out and the control harness. Any ideas
Thanks Travy
ps I am new to the forum. I belonged a long time ago with a different vet. Now I am back with this one
Old May 8, 2025 | 01:40 PM
Dads2kconvertible's Avatar
Dads2kconvertible
Sounds like something is plugged in backwards.
Old May 8, 2025 | 02:14 PM
Travy's Avatar
Travy
3rd Gear
I completely agree but there were only 3 plugs and they only fit one way
Old May 8, 2025 | 08:02 PM
Travy's Avatar
Travy
3rd Gear
So I heard from someone the wires going to the seat control can get pinched when you put your seat back in. I think this was my prob. I took seat out again and repositioned the wires and seems to be ok now . Fingers crossed. If my bat drains overnight then I have a whole different prob. Thanks for your help
Travy
Old May 9, 2025 | 11:16 AM
Sydwayz's Avatar
Sydwayz
St. Jude Donor '18
I have this problem with my Lexus after replacing the seat bottom. The seat f/r buttons bind on the trim of the side of the seat. I can still use/work them, but they do not “return to center” as a momentary switch. I have to manually move them forward, backward, to return to “neutral”.
Old May 13, 2025 | 07:31 AM
Moved to C5 Tech for some troubleshooting advice.
To Weird power seat driver side
