Rear End Metallic Rattle
Old May 11, 2025 | 11:24 PM
rob3eli's Avatar
rob3eli
Default Rear End Metallic Rattle
Can't find the source of a rattle I get on decel and when slightly reving the engine while at idle and in neutral.
Sound does not change when pressing in the clutch, I checked the common H pipe hanger springs and they were not the culprit.
Video link below. Any advice is appreciated.
Old May 13, 2025 | 03:03 PM
rob3eli's Avatar
rob3eli
Been researching like crazy and have seen it could be torque tube related? Likely the bearings inside the torque tube failed?
Old May 13, 2025 | 03:35 PM
redzg's Avatar
redzg
To me, that sounds similar to the loose plate I have inside one of my mufflers.
Old May 13, 2025 | 03:45 PM
rob3eli's Avatar
rob3eli
I've read that somewhere that the baffle plates inside become loose over time.
Old May 13, 2025 | 03:53 PM
lucky131969's Avatar
lucky131969
Jackstands won't cut it. If you don't have a lift, take it to a trusted shop. Everyone is just guessing.
Old May 13, 2025 | 04:09 PM
rob3eli's Avatar
rob3eli
Agreed, I'll take it to a shop tmrw and report back
Old May 14, 2025 | 12:58 AM
rob3eli's Avatar
rob3eli
Traced down the issue with a stethoscope. Sound is coming from the factory H pipe. Something is jingling inside there.
Old May 14, 2025 | 07:12 AM
SideOfTheRoad's Avatar
SideOfTheRoad
Could it be exhaust flutter/jingle from the under sized holes in the h pipe?
Old May 14, 2025 | 07:38 AM
rob3eli's Avatar
rob3eli
Yep, that or that piece is loose inside. The sound is definitely coming from there. Taking it to a muffler shop right now
Old May 14, 2025 | 11:29 AM
SideOfTheRoad
Keep us posted on what you find out.
Old May 14, 2025 | 11:47 AM
rob3eli's Avatar
rob3eli
It was the H pipe, installed an X pipe and the rattle went away
Old May 14, 2025 | 12:31 PM
rob3eli's Avatar
rob3eli
This thread helped a ton. OP had the same exact noise as me
http://www.corvetteforum.com/forums/...n-let-off.html
Old May 14, 2025 | 09:33 PM
SideOfTheRoad
Glad it was resolved. I guess I'm buying an x pipe now, I am in the same boat.
Old May 14, 2025 | 10:21 PM
rob3eli's Avatar
rob3eli
You got a metallic rattle/jingle on decel?
Old May 15, 2025 | 11:26 AM
SideOfTheRoad
Very light accel, and decel, same noise as in your vid. It's driving me insane.
Old May 15, 2025 | 12:37 PM
rob3eli's Avatar
rob3eli
More than likely the H pipe, hanger springs, or down stream o2 sensors
To Rear End Metallic Rattle
