C5 Corvette About engine oil
Old May 18, 2025 | 10:29 PM
Matchaice_C5's Avatar
Matchaice_C5
4th Gear
Default C5 Corvette About engine oil
Currently I am using tribodyn tri ex2 5w-30FS engine oil. What oil would you recommend for a C5 Corvette or LS1?
Old May 18, 2025 | 11:45 PM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
Any synthetic oily kind. It really doesn't matter.
Old May 19, 2025 | 12:28 AM
Dads2kconvertible's Avatar
Dads2kconvertible
Mobil has an oil finder on their US site, not sure if their Japan site has the same: https://www.mobil.jp/ja-jp
Old May 19, 2025 | 01:10 AM
vette4fl's Avatar
vette4fl
Mobile1 Super Car 0-w40
Do you own a Corvette built in 1993 or later? Do you like driving your Corvette more than changing its oil? If the answer to both questions is yes, then we recommend picking up Mobil 1 Supercar 0W-40. With one exception being the seventh-generation Corvette ZR1 where we recommend Mobil 1 15W-50 when on the track.
Old May 19, 2025 | 01:52 AM
Lowend's Avatar
Lowend
The only things that matter are displayed on the API medallion that exists on every quart of oil sold in the USA.
You need a Full Synthetic SN+, everything else is marketing BS.
Old May 19, 2025 | 07:02 AM
captain vette's Avatar
captain vette
Agree and don’t forget that it must be Dexos1 approved
Old May 19, 2025 | 08:28 AM
lucky131969's Avatar
lucky131969
Old May 19, 2025 | 09:33 AM
Mr. Black's Avatar
Mr. Black
Originally Posted by lucky131969
Bing Bing bing
Old May 19, 2025 | 04:14 PM
Lowend's Avatar
Lowend
Dexos is just a marketing term that GM made up to license to oil companies. It's like saying "Wider is better", there's pretty much no specs behind. API/ILSAC ratings are really comprehensive, there's no reason to use anything else as a standard.
There are some oils (Like Amsoil) that exceed a given spec more than others. But on a street car, if you get anywhere near the wrong end of those specs, many things have already gone horribly wrong. Endurance racer engines etc are a bit of a different story, but no one here is running a LMP1 engine on the street
Old May 19, 2025 | 04:49 PM
vette4fl's Avatar
vette4fl
So what are the best tires?
Old May 19, 2025 | 06:07 PM
Lowend's Avatar
Lowend
Old May 19, 2025 | 06:38 PM
Mr. Black's Avatar
Mr. Black
Super duper ultra high performance maximum grip summer only above 80 degrees outside only tires.
Or slicks.
To C5 Corvette About engine oil
