Strange and unique headlight issue
Old May 19, 2025 | 08:38 AM
RiverBoy's Avatar
RiverBoy
Default Strange and unique headlight issue
Hello, all. I'm new here and excited to work with anyone who can help me with my specific problems!
My 1998 Chevrolet Corvette (C5) headlights don't work properly. With the battery plugged in, which is a functional battery, by the way (it starts and drives), if I turn the switch on the turn signal stalk/multi-switch to turn the headlights on, nothing happens. The first click does turn on the daytime lights, but the second click to turn on the headlights doesn't do anything. However, I found that if the battery is disconnected, and I turn the switch all the way, and then reconnect the battery, there's a spark and the headlights pop up, but the lights don't come on. I can turn the switch off which closes the doors, but I can't open the doors again through the switch. Also, the high beams do not work if I push in the switch to turn them on, but if I pull it back (which is called the flash-to-pass feature), they'll come on as long as I'm pulling it back.
I checked the fuses with a multimeter and they seem okay (reading 00.0 at the 20k setting). I have yet to check the headlight control module itself, as I have no knowledge of how to do that.
Any ideas?
Old May 19, 2025 | 09:22 AM
lucky131969's Avatar
lucky131969
Originally Posted by RiverBoy
I found that if the battery is disconnected, and I turn the switch all the way, and then reconnect the battery, there's a spark and the headlights pop up, but the lights don't come on. I can turn the switch off which turns the headlights off, but I can't turn them back on.
You just stated the headlights do not come on at all, but then you state you can't turn them back on. Do the lights turn on or not?
If you can read schematics and have a DMM, you can isolate your problem. I encourage you do use the search function. 20 years of reading on this topic.
Old May 19, 2025 | 09:40 AM
RiverBoy's Avatar
RiverBoy
The low beam lights do not turn on. It's only the doors that will come up when reconnecting the battery.
Old May 19, 2025 | 09:47 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Here is your wiring for your headlight circuit…if you can’t read this schematic I highly advise you to seek out an electrical professional…unfortunately we can’t guide you step by step.
Old May 19, 2025 | 10:33 AM
RiverBoy's Avatar
RiverBoy
I'm a bit excited and anxious about driving it. I just bought it 2 weeks ago and the required registration papers should come soon, so I want to make sure it's all good and safe to drive. Going to get some engine codes pulled first thing. That should help me diagnose something, right?
Old May 19, 2025 | 10:57 AM
C5 Diag's Avatar
C5 Diag
Pulling “engine” codes aren’t going to give you any direction on a lighting circuit which are “B” or body codes…I don’t even think there are any DTC’s related to headlights…you can use the cars “built in code reader” through the DIC…my advise is to save your pennies and get yourself an aftermarket bidirectional scan tool if you want to diagnose your car…they are less than $500.00 these days….if you have a DVOM get some 4mm banana jack leads along with some back and piercing probes and alligator clips…a cheap “amp clamp” is another good piece of equipment to have…all these can be purchased on Amazon…BTW we use a 12 volt test light to check fuses and not a multimeter…you can buy one of these too.
Old May 19, 2025 | 11:11 AM
RiverBoy's Avatar
RiverBoy
More money to spend. Okay, thank you.
I bought the car from an auction, so I feel pulling codes wouldn't hurt either way.
Old May 19, 2025 | 11:16 AM
C5 Diag's Avatar
C5 Diag
Yes, go a pull codes but trouble codes aren’t part numbers…if you diagnose correctly you spend $100.00…you throw parts at it and you may spend $1000.00 and it still may not be fixed…good luck !!
Old May 19, 2025 | 11:17 AM
RiverBoy's Avatar
RiverBoy
Right. "Test, don't guess!"
Old May 19, 2025 | 11:18 AM
C5 Diag's Avatar
C5 Diag
That’s right !!
Old May 20, 2025 | 09:57 AM
RiverBoy's Avatar
RiverBoy
I found a used bidirectional scan tool on eBay for about $100 that claims to connect to my phone where I can control certain functions, such as activating the headlights, from the app. Does this seem like a good thing to try out? Can't hurt, right?
Old May 20, 2025 | 10:00 AM
C5 Diag's Avatar
C5 Diag
If that’s all you can afford you can try it.
Old May 20, 2025 | 10:28 AM
lucky131969
Ok...but you did not have to spend a dime to check your codes.....
https://www.corvetteforum.com/forums...dic-codes.html
Old May 20, 2025 | 10:38 AM
C5 Diag's Avatar
C5 Diag
No DTC’s can be found related to the headlight circuit..OP is better off looking at the inputs and outputs with a bidirectional scan tool.
Old May 20, 2025 | 10:53 AM
lucky131969
Yes, I am aware. Just making sure the OP knows he can pull codes without a scanner.
Old May 20, 2025 | 11:08 AM
RiverBoy's Avatar
RiverBoy
Pulling codes will be the first thing I do later after work. You've made me aware it won't really help the headlight issue, but I figure since I got it from an auction, changing all fluids and pulling codes are good maintenance tasks, just to make sure it's at least road worthy
Old May 20, 2025 | 11:29 AM
Dads2kconvertible's Avatar
Dads2kconvertible
Do yourself a favor and use a burner phone for all those sketchy apps. No reason for them to have access to your real phone that probably has all your contacts, banking info, healthcare data, etc.
Old May 20, 2025 | 04:38 PM
1999corvettels1's Avatar
1999corvettels1
I think I the same issue on my 1999 C5 after it being parked in the garage a long time, maybe a couple of years.
The headlights wouldn’t turn on, on the first drive after pulling car out of storage and the sun was setting turned on lights and they didn’t pop up, luckily was close to home not on a road trip!
In my case I think the headlight switch was maybe gummed up inside from lack of use, found if I turned the switch from off to headlights on quickly the lights would come on, sometimes it took 2 or 3 tries twisting it kind of quick, then they would pop up.
Eventually the issue went away and being lazy never investigated farther.
Old May 21, 2025 | 11:05 PM
CFight's Avatar
CFight
Are the bulbs good?
To Strange and unique headlight issue
