Need help replacing fuel filter on 01 convertible c5
Old May 21, 2025 | 09:30 PM
Kevvkevv72's Avatar
Kevvkevv72
Default Need help replacing fuel filter on 01 convertible c5
Hi guys I need some help with replacing my fuel filter on my 2001 convertible c5 corvette. I see a lot of videos of ppl doing it on the zo6 model with ease because they have a lot more space. However on my convertible I can barely fit a hand inside, any tips and help would be greatly appreciated thank you.
Old May 21, 2025 | 09:48 PM
lucky131969's Avatar
lucky131969
Do you have an automatic transmission?
Old May 21, 2025 | 09:51 PM
Kevvkevv72's Avatar
Kevvkevv72
Default Yes it’s an automatic
Old May 21, 2025 | 09:52 PM
Kevvkevv72's Avatar
Kevvkevv72
Old May 21, 2025 | 09:59 PM
lucky131969
That's the problem, there is less room with an auto......and all ZO6s have manuals. Service manual recommends lowering the left muffler.
Old May 21, 2025 | 10:00 PM
Kevvkevv72's Avatar
Kevvkevv72
Default Thank you señor
Old May 22, 2025 | 11:36 AM
USN32's Avatar
USN32
I was able to reach my hand up in there without disconnecting anything on my 2001 A4 Coupe. If you can't, then do like Lucky said and disconnect the muffler from your h/x-pipe and maybe the driver exhaust hanger spring so that you can shift things around a little for access. I did the same on my passenger side last weekend so I could reach up and disconnect stuff to drop and replace the fuel tank.
Old May 22, 2025 | 12:47 PM
Kevvkevv72's Avatar
Kevvkevv72
Default I did exactly what lucky said and it worked perfectly, thank you guys for the help!
Originally Posted by usn32
i was able to reach my hand up in there without disconnecting anything on my 2001 a4 coupe. If you can't, then do like lucky said and disconnect the muffler from your h/x-pipe and maybe the driver exhaust hanger spring so that you can shift things around a little for access. I did the same on my passenger side last weekend so i could reach up and disconnect stuff to drop and replace the fuel tank.
To Need help replacing fuel filter on 01 convertible c5
