Starter Solenoid Replacement
Old May 22, 2025 | 04:32 PM
LannyL81's Avatar
LannyL81
Default Starter Solenoid Replacement
I need to replace the solenoid due to a snapping-off the solenoid engagement stud. Thought the nut was turning.....nope, it was the stud twisting and breaking off!
I know I can just get a new or rebuilt starter, but all I really need is a replacement solenoid. I went searching and was not able to find one that says it fits my '04.
Anyone happen to know of a web source for starter solenoids?
Does not look like I can replace the broken-off stud as the case needs to be removed. The case appears to be compressed and not serviceable.
Old May 22, 2025 | 06:43 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
If you are going that far I’d just replace the starter and be done with it.
Old May 22, 2025 | 07:13 PM
lucky131969's Avatar
lucky131969
On a SBC I would replace the solenoid....on a C5 LS....definitely the starter.
Old May 23, 2025 | 07:50 AM
LannyL81's Avatar
LannyL81
Yes I agree...replace the entire starter.
As far as I know, it is the original starter, so 21+ yrs old now. Just makes no sense to put that old starter back on.
And after reading on the Forum, think I will get a starter that uses two long bolts.
Thanks for the replies.
Old May 23, 2025 | 05:42 PM
mmartinez's Avatar
mmartinez
Ah, the good old days of SBC, I couldn't afford to replace the starter, so I'd buy a kit that consisted of new brushes, and bushings, also if the solenoid cover wasn't broken we would loosen and turn the main terminal 180 degrees to get new copper contact area, and maybe replace the starter drive if it was acting up.
Old May 29, 2025 | 06:19 PM
LannyL81's Avatar
LannyL81
Oh yes, the ole SBC days.
To Starter Solenoid Replacement
