Is there a CAM FAQ or tutorial?
Old Feb 13, 2003 | 01:41 PM
C5B's Avatar
C5B
Default Is there a CAM FAQ or tutorial?
I see these numbers thrown around, but have no idea what 224/224 LSA114 means?!?! Is there a doc/faq somewhere that explains what is what? I DO understand how cams work, but have yet to learn how to choose one based on numbers.
Thanks!
- C5B
Old Feb 13, 2003 | 01:59 PM
SideStep's Avatar
SideStep
Default Re: Is there a CAM FAQ or tutorial? (C5B)
Highly simplified....
intake lift / exhaust lift / lsa(lobe separation angle) / duration( degrees open)
224 / 224 / .114 / .561
[Modified by SideStep, 7:04 PM 2/13/2003]
Old Feb 13, 2003 | 02:09 PM
Chris@SD's Avatar
Chris@SD
Check out our website under the tech section. We have an article that explains it all.
If you need help picking a cam just call or e-mail us.
Hope this helps
Old Feb 13, 2003 | 03:34 PM
newbie's Avatar
newbie
Default Re: Is there a CAM FAQ or tutorial? (Chris@SpeedDemon)
Check this link for a laymans explanation as well as animation of a mild -vs- a performance cam.
http://auto.howstuffworks.com/camshaft1.htm
:steering:
Old Feb 13, 2003 | 04:21 PM
2KVetteMan's Avatar
2KVetteMan
Hope this helps
Sent you an e-mail Chris :cheers:
To Is there a CAM FAQ or tutorial?
