ASP pulley kit VS ATI balancer??
I plan on turning about 7200 rpm out of my new motor and want to go with an underdrive set up. Do I need the ATI balancer? What is the difference in the underdrive ratio of the ATI and ASP?
Thanks, Dale
Thanks, Dale
Re: ASP pulley kit VS ATI balancer?? (DALE C)
The ATI ballancer is stock size. The ASP is smaller giving you more HP to the rear wheels. :smash:
vetterdstr :cheers:
vetterdstr :cheers:
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
I believe ATI makes an underdriven super dampner as well which i definitely the way I would go if you are going to do a ton of racing at high RPM. The balancer helps take harmonics out of the rotating assembly.. It is quite expensive, but well worth it for a race motor in my opinion.
I am putting one on my 565ci Big Block Chevy motor I am getting built.
[Modified by MattG, 2:59 PM 2/13/2003]
1 Post
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Re: ASP pulley kit VS ATI balancer?? (MattG)
ATI makes some pretty good stuff (IMHO).
Here's a link for the Super Damper.
http://www.martelbros.com/cgi-bin/st...serpdamper.htm
