Removing shifter knob?
Old Feb 13, 2003 | 08:11 PM
Clean Freak's Avatar
Clean Freak
Navigator
Default Removing shifter ****?
Being mechanically inclinded,owning muslcle machines all my life but Im stumpted.... I bought cool new alum. pistol grip but cant get old **** twisted off.. new one has bushing twist on when trying removal bottom twist but appears **** is glued????????? :confused: :withstupid:
Old Feb 13, 2003 | 08:18 PM
LoneStarFRC's Avatar
LoneStarFRC
Default Re: Removing shifter ****? (Clean Freak)
Are you trying to remove a factory **** or an aftermarket ****?
[Modified by Tx99FRC, 7:38 PM 2/13/2003]
Old Feb 13, 2003 | 08:20 PM
SideStep's Avatar
SideStep
You need to pop off the shift pattern, take a pair of needle nose vice grips, lock onto the "key" and tap the vice grips upward with a hammer. After removing the key the **** will screw off...
:cheers:
[Modified by SideStep, 8:20 PM 2/13/2003]
Old Feb 13, 2003 | 08:39 PM
LoneStarFRC
Default Re: Removing shifter ****? (SideStep)
:cheers:
:iagree: As long as it's a factory **** you're removing. Do a search and find a lot of good tips on this topic.
Robert :)
[Modified by Tx99FRC, 7:39 PM 2/13/2003]
Old Feb 13, 2003 | 09:04 PM
ndirishr1's Avatar
ndirishr1
Have patience if it's a factory ****. The shift pattern will pop off esily. The wedge will take some time and work. Mine was a pain. Once the wedge is out it will unscrew easily. Good luck.
Old Feb 14, 2003 | 12:01 PM
SteveL2's Avatar
SteveL2
Here you go, this shows you the process --> http://www.vetteessentials.com/instr...t_install.html
Good luck. :seeya
Old Feb 14, 2003 | 02:35 PM
TRR's Avatar
TRR
:iagree:
You might want to put a drop of WD40 on the key and let it soak for a few minutes. Mine popped right out.
TRR :cheers:
Old Feb 14, 2003 | 05:19 PM
Carsnob's Avatar
Carsnob
Default Re: Removing shifter ****? (TRR)
I had to use vice grips, a block slightly taller than the shifter, and a screwdriver about 16" long.
Put the block behind the shifter.
Clamp the grips on the L & R sides.
Stick the screwdriver through the hole and rest the tip on the block.
PULL UP ON THE HANDLE!!!
Old Feb 14, 2003 | 05:30 PM
mods to come's Avatar
mods to come
The key is a : :banghead: to get off. I used vise grips and it finally came off. Then the handle unscrewed easily
Old Feb 21, 2003 | 09:30 PM
Clean Freak
Navigator
Hey guys thanks for the suggestions. Finally found time yesterday to mess with this and the block of wood, needle nose vise grips, screwdriver was the winning tactic even though i broke the key in 3 pieces new alum. **** looks cool .... :hat :cheers: :hurray:
Old Feb 22, 2003 | 11:07 PM
SideStep's Avatar
SideStep
Three pieces?!?!
How? :confused:
Old Feb 22, 2003 | 11:46 PM
C5stein's Avatar
0C5stein
Former Vendor
One of our Corvetteforum buddies in Germany sent me two of these really cool paint can openers. You hook them under the Biotch Key, pry to the side and the key just pops out. I wish I could find his name to thanks him again. These little beauties probably save me an hour a week. They are the bomb! :cool:
Old Feb 23, 2003 | 05:33 PM
CR555's Avatar
CR555
Default Re: Removing shifter ****? (C5stein)
Told you Mark!!! Since you've got a lot of experience with the other key removal methods, you really can tell the difference! :thumbs:
These tools are amazing. As a test I put the OEM **** on my (uninstalled) Hurst shifter, hammered the pin/key in. It sat a lot tighter than on my stock shifter. :eek: I had to use much more force than before, but removing the pin still was just a matter of seconds! :crazy:
[Modified by CR555, 9:37 PM 2/25/2003]
Old Feb 23, 2003 | 09:55 PM
C5stein's Avatar
0C5stein
Former Vendor
Default Re: Removing shifter ****? (CR555)
Thanks again Don,
Hey I was looking at the back of you car, I could see how the license plate blocks the US version of back up lights so your inner tail lights have the clear back up lights, but are those other red lights on the bumper required by law there in Germany?
Old Feb 24, 2003 | 02:53 PM
MySea6's Avatar
MySea6
Those things look perfect for the job. :thumbs:
A couple of screw drivers works well also. I have never not been able to remove a key this way on 12+ stock shift *****. :cheers:
To Removing shifter knob?
