Supercharger on LS6
Ps I have a spare ls6 that my piston shattered wanting it to build it from the bare block up. Any suggestions on what I should do ?
Or just throw the A&A supercharger kit on the stock LS6 and see how far it goes before detonating. Maybe it will go 100,000 miles. Who knows.
Provided the OP is starting out with a well maintained engine, that LS6 can easily be at 600HP all day long on a conservative tune and 10 psi.
With this other engine sitting should I be focusing on my new engine that’s in the vette right now or build the broken one. Which I would send to a machine shop and bore it to a 383 at least that’s what my buddies recommended. I’m just trying to avoid what happened last time and play it more on the safe side rather then just jumping.
I do appreciates your guys input.
If looking for more than the 50% HP than stock (more than 600hp), then you drop standing cylinder compression and bring is back up with the blower instead, and start reinforcing the piston and rods (forged), to take the extra pressure that is going to create the more horse power.
As for close to, or above 600hp, now you get to bullet proof the rest of the drive line, to take that extra 200 hp abuse next.
And remember, the engine is being forced feed air, so don't think of it like a normal aspirated engines, that your porting/flowing heads and big radical cam, and trying to get the engine to breath better of its own still.
As for 600hp and the drive line bullet proofed as well,
very road coarse-able, but past the point with more HP, forget road courses use, since your boxing yourself in for straight line use instead.
Yes, may be 1/2 second faster down the straight, but going to be a nightmare in the techinal sections trying to hold the car on line as back end walks out over and over again with TVS blower.
Note, forget trying to use centrifical blower car on the road course car. The boost kicks in much later in the RPM, and when they do kick in, back end just comes whipping around on you. With TVS blower, you can use higher gear to grunt the car out of the corner, since torque of the motor goes linear max, pretty much off idle instead.
Hence HP is thought of as the speed that when you hit the wall.
while torque, is how far your going to take the wall with you when you hit it instead.
This is the route I would go IMO
