Measuring Tread
Old Feb 14, 2003 | 01:00 AM
knesbitt's Avatar
knesbitt
Default Measuring Tread
How does on measure the tread on a tire using a coin? I forgot what was the technique.
Old Feb 14, 2003 | 01:08 AM
Richin Chicago's Avatar
Richin Chicago
Default Re: Measuring Tread (knesbitt)
Here you go:
http://www.tirerack.com/tires/tirete...eplacewhen.htm
Old Feb 14, 2003 | 07:31 AM
Cajun99's Avatar
Cajun99
I just check mine by "eye". Obviously when the tread and "wear bars" get pretty close to even it's adios time for the tire. Some folks probably wouldn't even wait that long to get rid of them. :yesnod:
Old Feb 14, 2003 | 05:14 PM
Gary2KC5's Avatar
Gary2KC5
Default Re: Measuring Tread (Cajun75)
I use a guage that measures in 32's or mm
Old Feb 14, 2003 | 07:09 PM
WhiteC5Vette's Avatar
WhiteC5Vette
St. Jude Contributor
Default Re: Measuring Tread (Gary2KC5)
http://www.autotoolexpress.com/tirtreadguag.html
Same as the one I have and probably the same as Gary2KC5 uses.
[Modified by WhiteC5Vette, 6:10 PM 2/14/2003]
Old Feb 15, 2003 | 08:51 AM
Oldvetter's Avatar
Oldvetter
Default Re: Measuring Tread (WhiteC5Vette)
Use a penny. If you can see the top of Lincoln's Head, it's time to replace tires.
It's just as easy to look for tread bars, supposely if you see 3, it's time to replace tires.
To Measuring Tread
