power antenna
Old Jun 17, 2025 | 03:06 PM
scard1956's Avatar
scard1956
6th Gear
Default power antenna
My original motor and mast had to be replaced. Ordered a new one which is supposed to be a direct replacement. Installed but does not work. Cannot get the mast to go up/down.Of course wire colors do not match.Has anyone had a similar problem
Old Jun 17, 2025 | 03:21 PM
lucky131969's Avatar
lucky131969
Replaced why? For the same problem, or something different? Have you done the minimum 12v and ground checks at the connector?
Old Jun 17, 2025 | 03:28 PM
scard1956's Avatar
scard1956
6th Gear
the plastic piece broke way down in the motor.I do have 12 volts at the connection
Old Jun 17, 2025 | 03:44 PM
lucky131969
The motor connector should plug into a harness with an orange, green, and black wire. You should have 12v on the orange wire at all times, 12v on the green wire when you turn on the radio, and a ground on the black wire.
To power antenna
