QuickTime bell housing install notes - 2002 c5 manual
I'm currently going through this monster of a job and wanted to give pointers, as there is not much coverage of this particular install.
The bell housing will not fit without some significant work.
Obviously, if you have long tube headers, you'll need to drop them to gain access. The clutch assembly must go in first, and then the bell housing tries to slide over. However, there is no clearance unless the front subframe of the car is dropped an inch or 2. I just lowered the nuts for the subframe all the way, and then removed the rear nuts and dropped the cradle on a jack. I do have an ACT single disk clutch in it, and so other clutches may have more or less clearance, maybe you won't have to drop the cradle.
Additionally, long tube headers require some significant cutoff wheel work on the bell housing to clear, at the 4/5 o'clock and 7/8 o'clock positions.
If your slave cylinder has a shim on it, like some manufacturers recommend to get the proper clearance of the throw out bearing, then your slave and remote bleeder lines will interfere with the bell housing - requiring more cutting. I haven't checked without the shim on the slave, but the clearance is so tight that it may require some cutting straight out of the box with a factory style setup.
The bottom of the bell housing assembly hangs almost 2 full inches down under the oil pan, and that would be a very unfortunate thing to have smacking all over the ground or speed bumps, as these cars have pretty low ground clearance anyway. This, again, requires some significant modification to bring it anywhere near an acceptable ground clearance height.
A final note, the engine plate to bell housing nuts and bolts are almost impossible to attach with the motor in the car. Just forget about it.
Holley sells this thing with essentially no install instructions other than "remove old bell housing. Install new bell housing" and leaves the rest to the consumer to figure out, which is unfortunate.
Figured I'd post this to perhaps help the next guy who thinks that this is almost a factory replacement - not even close.
Questions are welcome, and I'll let you guys know anything you'd like about this particular job.
Riley
Riley
Here's one part of the install. I know there are other shots somewhere further down with the breather holes cut.
Quicktime Installed
