Fuel Guage Reads Empty
Old Jun 24, 2025 | 08:59 AM
d.moscatelli@comcast's Avatar
Default Fuel Guage Reads Empty
I've owned my C5 for 21/2 years. daily it 9-10 months of the year. Every 2-3 months the fuel guage would read inaccurate and I would go to the parts store and get Tecktron , dump it in the fuel tank and everything would be ok for 2-4 months. But I haven't had to add an additive for the last 6 months. Last Friday I was driving and the "Check Guages " light came on the guage cluster. Checked my guages and the fuel guage was reading empty, although I had filled up the tank the day before.
I'm going out to the parts store in a few minutes to get some tecktron, but if that doesn't work, I want to check with you guys as to my next steps or hear any experiences you all may have had with this issue.
Old Jun 24, 2025 | 09:26 AM
mcbrucey's Avatar
mcbrucey
Mine hasn't got this bad yet, but when I fill up with a new tank, the gauge moves very slowly to Full. I fear I am heading in the same direction as you.
Old Jun 24, 2025 | 10:16 AM
Ltngdrvr's Avatar
Ltngdrvr
Fuel level senders seem to be an issue on these C5's, very likely you will need to change yours.
Old Jun 24, 2025 | 10:45 AM
sonicss33's Avatar
sonicss33
There comes a time when the Techron trick no longer work. You seem to be there, time to replace the sender. Really is not that hard to do yourself. Some years are a little more challenging. I did mine “98” in less that 2 hrs. Good luck.
Old Jun 24, 2025 | 10:46 AM
rrwirsi's Avatar
rrwirsi
I have had this problem for several years. At first, Techron worked but then it did not no matter how much I put in. Now when I fill up, the gauge goes to empty until I hit a significant bump in the road and/or make several sharp turns then the gauge starts working again until the next fill-up. I decided to just live with this issue.
Old Jun 24, 2025 | 10:58 AM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
Working 100% of the time 60% of the time is not a fix lol. Techron is a half assed band aid when it comes to the senders.
If you have a 2003.5 or older car replacing the senders is not the scary monster that many just assume it is.
If you have a later C5 I'm sorry and I really do feel bad for you.
I think the trick these days is trying to find new OEM senders. I believe they are drying up. For years Rock Auto had them for around 50 bucks.
Also, if have the check gauges light coming on that is a sign that the car knows there is fuel sender faults and it will store codes for it that can help point you in the right direction.
Also if you happen to have HP tuners or another good bidirectional scanner tool you can see the fuel level sender voltages real time at all times and this will absolutely tell you which one or if both senders are acting up.
Old Jun 24, 2025 | 11:01 AM
DDaaryl's Avatar
DDaaryl
On my first failure, it took less than two miles of driving for Techron to do its magic. A few years later it took multiple doses and almost 100 miles for the gauge to come back to life. Now I add Techron to the tank 3-4 times every year and it's all good. Gald I was patient and didn't tear into it.
Old Jun 24, 2025 | 11:11 AM
Mr. Black's Avatar
Mr. Black
out of curiosity how much have you spent on all that?
You can have a fuel sender out of one of these cars in under a half hour. It's not as hard as people make it out to be (pre 04)
Old Jun 24, 2025 | 11:48 AM
grinder11's Avatar
grinder11
Good, no, excellent point. Techron helped me, until it didn't. It's also not cheap. I wish I'd have changed senders years ago. I finally did a couple of years ago. At that time Rock had only one side. You had to buy 2 of the same side and swap float assemblies. Fairly easy to do. I killed all power to the garage and opened all the doors for ventilation. At the prices the senders and Techron were going for then, I figured about 5 or 6 cans of Techron cost the same as 1 sender. So, after 10-12 cans, you could've bought both new senders. Put another way, you've spent enough on Techron to buy new senders, but now you still need the senders. Techron is kicking the can down the road, and sooner or later the can won't kick far enough.....
Old Jun 24, 2025 | 01:56 PM
zane8's Avatar
zane8
If you get to the point where you are thinking of diving into the sender replacement job, do yourself a favor and make sure you have the correct reference voltage from the PCM to the rear of the car. I changed the senders and it didn't fix the problem.. In the end, the PCM was not putting out the correct voltage, so the gauge wouldn't work regardless of sender age. My PCM problem may have been an outlier, but checking it would be a logical first step after the Techron fails. My long-winded saga is here https://www.corvetteforum.com/forums...placement.html.
Z
Old Jun 24, 2025 | 02:46 PM
OK, much useful input. Thanks. So on my 98 , are there 1 or 2 sending units? If 2 I assume there is one in each tank. I'm guessing the tanks should be nearly empty of fuel before I start to remove the sending unit ( s )?
And also will I gain access to the sending units via the rear wheel openings after I remove the rear wheel ( s )?
I will look this up on YouTube videos, that has always been my main source for the C5 for info, usually.
Old Jun 24, 2025 | 03:11 PM
zane8's Avatar
zane8
You have two sending units which can be accessed by the circular covers in the wheel wheels. The passenger side has just the level sender and the drivers side has a level sender and the fuel pump. Getting the drivers side out and back in is more tricky since there's a lot of stuff going in that hole - you have to maneuver both the pump and the sensor. You must ensure that the float arms on the sensors are free to move once inside the tank. Yes, you want the tanks as empty as possible. I drained the whole thing by pumping it out via the fuel rail.
Z
Old Jun 24, 2025 | 03:53 PM
DDaaryl's Avatar
DDaaryl
Personally I could not get one or both of the fuel senders out of my car in a half hour. I purchase Techron at the local auto store when they have a buy one get one free (BOGO) so it might cost $6-7/bottle. I may have spent $30-40 on Techron in my lifetime. Way cheaper than sending the car out for service and possibly ending up with aftermarket (Chinese) parts with questionable quality.
Old Jun 24, 2025 | 04:31 PM
USAZR1's Avatar
USAZR1
Last I heard, the sending units have been discontinued. Anyone purchased them, lately?
Old Jun 24, 2025 | 06:56 PM
Moved to C5 Tech.
Old Jun 25, 2025 | 02:14 PM
SkyTigress's Avatar
SkyTigress
They are out of stock on Rock Auto for a 2004. I'm scared now lol, hopefully my car will be ok for a while *knock on wood*
Old Jun 25, 2025 | 02:27 PM
rrwirsi's Avatar
rrwirsi
You will be fine. Take a deep breath. Just note the mileage at fill up and refill at 200. That is what I do for the past 3 years and car is running just fine.
To Fuel Guage Reads Empty
Old Jun 25, 2025 | 03:27 PM
57gman's Avatar
57gman
Mine occasionally will go to empty while driving over an hour,, check engine light comes on. Then, it goes back to normal after 20 minutes or if I turn it off. Then the next time I start it, it's perfect!
Shhhhh!!!
Old Jun 25, 2025 | 03:44 PM
Fast one's Avatar
Fast one
Fuel sender problems for many brands of cars were caused by fuel companies putting sulphur in the gas, I think the class action lawsuits mostly ended that practice. You might try buying gas from a different company and see if that helps, the gas blend for the climate in your part of the country might also cause sender problems.
Old Jun 25, 2025 | 04:43 PM
sonicss33's Avatar
sonicss33
I did this one time before replacing the sender. I removed the sender and took to the workbench, cleaned the crud off of the “wire element” with a pencil eraser and tiny screwdriver. Reinstalled and it worked for about 18 months longer. I was then lucky to find a new replacement, I believe I found it from RockAuto.
