I Need Tire Help...!!
Old Feb 14, 2003 | 04:58 PM
GmasterB's Avatar
GmasterB
Default I Need Tire Help...!!
I'm in need of some sticky tires for my rears. I have 18x10.5 rims, and I was really wanting some DR's, but apparently no one makes them for 18's.
So what do you guys suggest for 18" rims? I really need some sticky tires, these 4.10's just cook my runflats. I'm not going to buy 17's are anything like that, so no "get ZR1 rim's" or anything like that. Just want input on the 18" rim. Thanks....
Old Feb 14, 2003 | 08:02 PM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
Default Re: I Need Tire Help...!! (GmasterB)
BFG KD's
Old Feb 14, 2003 | 08:25 PM
tom p's Avatar
tom p
:iagree: g-force's rule may the force be with you
Old Feb 15, 2003 | 12:00 AM
GmasterB's Avatar
GmasterB
Default Re: I Need Tire Help...!! (tom p)
I just checked tiresonline.com and they have them for $311, is that a pretty good price? I tried to check the tirerack, but their damn website sucks, and I can't just type in the size and stuff that I want to see. I even tried using the ZO6 selection and it says "click see all to view all choices." No where on the damn screen was there a "view all" button to click :mad Someone needs to redo that site!!
Old Feb 15, 2003 | 09:34 PM
tom p's Avatar
tom p
I bought my kd's thru tire rack and my 275-17/295-18 were about 1200. Go to the site and call the 800 number . I couldn't figure how to order online either! Not a very user-friendly site!!!! But 4 days later---ups to the rescue!! :chevy :chevy :party:
Old Feb 15, 2003 | 09:53 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
When you go to the tirerack site, just click on the link that says "search for your tire size". The plug in your size, and it lists all the brands available in that size.
Assuming you're looking for a 295/35/18, tirerack's price is $345 for the BFG g-force KD, so $311 sounds like a good deal.
:cheers:
[Modified by Y2Kvert4me, 2:54 AM 2/16/2003]
Old Feb 15, 2003 | 09:56 PM
LoneStarFRC's Avatar
LoneStarFRC
Default Re: I Need Tire Help...!! (Y2Kvert4me)
Might also consider Kuhmo's too. Hey at least they're pretty inexpensive in case you "fry'em". :D
Robert
Old Feb 15, 2003 | 10:04 PM
GmasterB's Avatar
GmasterB
Default Re: I Need Tire Help...!! (Tx99FRC)
How do the Kuhmo's compare sticky wise?
Would it be OK to run KD's in the rear and Kuhmo's up front, or is using different tires not good?
Thanks for the input guys, I appreciate it...!!
Old Feb 15, 2003 | 10:07 PM
LoneStarFRC
I have'nt used Kuhmo's myself but in looking at the tread wear rating it seems a bit lower than the others out there so I'm thinking maybe a good bit softer rubber compound.
Old Feb 16, 2003 | 10:46 AM
BLOWN IN NC's Avatar
BLOWN IN NC
The latest Car and Driver tests the Kunhos against Kds and the new yoko AVS--The kumhos finished only seconds (2-3) behind the KDs in the dry test and first in the wet test where the KDs were behind them. They are very cheap compared to the ones they beat.
Old Feb 16, 2003 | 11:06 AM
C5-VERT's Avatar
C5-VERT
Default Re: I Need Tire Help...!! (BLOWN IN NC)
Treadwear rating is a big factor on how soft the tire is. Here are some of the lowest treadwear rating tires(which means they are softer and wear faster).
Bridgestone S02 (NOT S03) (also discontinued but they still have them in stock)
Yoko AVS Sport
BFG KD
Old Feb 16, 2003 | 11:44 AM
bogielake's Avatar
bogielake
Gmaster:
I just tubbed my car and have a set of the KD's with less than 2000 miles on them, 295 rear, 275 fronts mounted on 2002 Z06 rims complete with caps and sensors if you interested. Send me an email, bpschmidt@comcast.net.
Brad
To I Need Tire Help...!!
