starting problem
Old Jul 8, 2025 | 02:50 PM
Bigrip's Avatar
Bigrip
1st Gear
Default starting problem
I have a 2004 commorative edition the problem I'm having is it want to start some the time you can get in it an turn the switch it will turn over an run for a few seconds then go dead you can start it again and it does the same thing ten the next time you start it it fires right up. You can drive it with no problems any ideas on what i should look for as to why it is doing this with trying to start it.any feedback will be appreaciated.its a 2004 with 78000 miles on it
Old Jul 8, 2025 | 05:42 PM
mmartinez's Avatar
mmartinez
Retrieve and post any codes.
