How Much to Fix Leaking Differential?
Old Jul 9, 2025 | 09:11 PM
57gman's Avatar
57gman
Default How Much to Fix Leaking Differential?
I know that's not an easy question to answer but maybe you have a dollar range? I'm curious.
Old Jul 10, 2025 | 07:31 AM
mykream's Avatar
mykream
Where is it leaking from? Do you have pictures?
Old Jul 10, 2025 | 11:08 AM
Beast's Avatar
Beast
FYI, if you are able to lay on the ground and get up safely. It’s easy to take pictures of the diff, you don’t need a lift.
Old Jul 12, 2025 | 04:32 PM
57gman's Avatar
57gman
Default Almost Done!
I do have pictures, but its not the right format to attach to a message. The latest is the housing on the differential housing is cracked? You can't buy a new unit and the dealer found it on Ebay...... $1,200 dollars later.
Good or bad but will be fixed!!!
Old Jul 12, 2025 | 05:23 PM
Dads2kconvertible's Avatar
Dads2kconvertible
Ahhh, the old differential housing housing. It all makes sense now.
Old Jul 13, 2025 | 11:22 AM
photonhunter's Avatar
photonhunter
Active Streak: 90 Days
I do have pictures, but its not the right format to attach to a message.....
So change the format. a trivial exercise.
dan k.
Old Jul 13, 2025 | 04:55 PM
Beast's Avatar
Beast
A complete stage 2 differential from RPM with gears of your choice is 2300. Do your research before throwing 1200 for a cracked housing.
I’ve got the 3.73 stage 2. 🤪
To How Much to Fix Leaking Differential?
