2001 c5 ac compressor nit engaging.
ac compressor clutch wont engage.
evacuated the system and recharged with no clutch engaging.
with gauges on pressure is 85 and high side matches
Will not take anymore refrigerant.
Replaces pressure sensor
replaced relay 34
34.fuse is good
Relay 30 and 87 jumped no clutch but fans kick on
Pin 85 at the relay- connected to dmm then the other lead to the negative battery terminal = 0.026V should pin 85 be zero?
Just fixed it back ground behind passenger headlight
