Cold passenger warm driver issue
Old Jul 16, 2025 | 08:07 PM
Woopigsooie00's Avatar
Woopigsooie00
Default Cold passenger warm driver issue
I evacuated my system and recharged it but I am.having an issue with the passenger side cold and center/driver side warm. If I swapped it to defrost it is also warm.
if i turn the temp to heat it does get hotter.
No codes on dic
I checked driver side blend door acuator and it is working.
any ideas?
Old Jul 16, 2025 | 08:17 PM
lucky131969's Avatar
lucky131969
any ideas?
Typical of an undercharged system. How much refrigerant did you add?
Old Jul 16, 2025 | 09:51 PM
Woopigsooie00
I thought so too but I filled it until the low side was 55 and high side 225 @ 88°
Old Jul 16, 2025 | 09:55 PM
bookyoh's Avatar
bookyoh
Have you checked your suction line to see if it is cold? It should feel about the same temperature as the high side line after the orifice tube.
Old Jul 16, 2025 | 10:22 PM
lucky131969
Ok....so again.....how much refrigerant did you add?
Old Jul 17, 2025 | 07:49 AM
Woopigsooie00
added
vacuumed down
added
2 oz pag
Almost 2 lbs of refrigerant. I pushed it high just to see if it would change the temp on that side.
Old Jul 17, 2025 | 08:09 AM
lucky131969
added
vacuumed down
added
2 oz pag
What does the sticker on the inner passenger fender state your refrigerant capacity is?
Why was the oil added? Did you replace something in the system?
I'm utterly confused why you would over-service the system. You started with a previously empty/evacuated system.....and you are servicing to a target pressure instead of servicing to spec to establish a baseline.
I assume that.......
-You otherwise had a working system that was not damaged or missing components
-You checked/replaced the orifice tube
-Your system was under vacuum for a period of time with a pump, you closed the valves on the servcing equipment, turned off the pump, and the vacuum held
-You used 12 oz cans
-You purged the hoses on the equipment
-You compensated 1 oz loss per can, 2oz loss for servicing hoses
-You used a scale
Old Jul 17, 2025 | 08:14 AM
Woopigsooie00
-You used a scale
it is not longer over serviced. After I serviced it to the correct pressure and the driver side blend door accuator was not the issue. I added more refrigerant to see if it would correct the issue. It did not.
So lets just assume refrigerant level and the driverside blend door acuator are not the issue. What is the next ?
Old Jul 17, 2025 | 08:19 AM
lucky131969
If you are not going to share exactly what you did, I'll pass. Good luck
Old Jul 17, 2025 | 09:45 AM
mmartinez's Avatar
mmartinez
Sometimes it's better to take the car to a shop that has a ac service machine, I am talking from my own past experience.
Old Jul 17, 2025 | 01:37 PM
Woopigsooie00
pretty sure i did. What more exact details do you need? I just know its not low on refrigerant. I am just trying to move past the thought that it is low on refrigerant to find the real cause. Because thinking tbat is just wasting time
Old Jul 17, 2025 | 01:52 PM
Vox Machina's Avatar
Vox Machina
Just to confirm, if you hook your gauges to the system and turn the A/C on, what are the pressures at 2k rpm? Just trying to verify the system is operating correctly.
What is the temp coming out of the drivers side? Hot? Warm? Luke-warm?
How about the center vent?
Have you inspected the evaporator to ensure there's no blockage across part of it?
And how did you verify the blend door was working?
Old Jul 17, 2025 | 05:22 PM
bookyoh's Avatar
bookyoh
Your low side is way too high.
Do you have a cold suction line? If not, and you have a correct charge, and your orifice tube is seated without a torn oring, then your compressor is not running at full stroke.
The compressor has a control valve in the rear casting. It determines how much the compressor needs to pump based on the suction pressure. There are failure modes that can mess up the valves ability to control correctly.
Overcharge will elevate the low side pressure too but 55psi seems high even with overcharge.
To Cold passenger warm driver issue
