Can't change AC temp on driver's side
Old Jul 21, 2025 | 11:45 AM
Atarian's Avatar
Atarian
8th Gear
Default Can't change AC temp on driver's side
I just recently bought a very low milage one owner 1999 C5 convertible. The car is equipped with dual zone AC. One small problemn I am having is i am unable to change the temperature settng for the driver's side. I rotate the **** clock and counterclockwise and it just stays on 73. I tried switching auto to manual on the control panel but no luck. The outside temperature sensor seems to work fine. Any ideas? I have not tried anything else yet. Edit. I did pull the fuse in the passenger side footwell for at least 10 minutes while I went to do something else. I know that is supposed to be for the actuator reallignment. No help to my problem though.
