Hi everybody, I have the wheels off my 98 vert, for new tires, painting the calipers, and general cleaning. I decided that with 36k I would go ahead and put new brakes on. Just going to go with OE parts, I have the pads, and am getting ready to remove the calipers so i can get the rotors off for turning. My question is this, I have the actual caliper off of the left rear, but the bolts for the part that carries the pads are really stubborn. Before I open the can of whoop azz, is there anything I should know? I.E. left hand threads etc.....
Thanks for any help, Doug
That is an interesting point. I did not know that it was not recommended to turn them. I had read other posts about dealers turning rotors that were warped. Mine have very slight warpage, but I was more concerned with the actual surface of the rotor. Sounds like I should spring for new rotors. I will still need to get those bolts out though. The car is on jack stands, if it was on a lift, I could get better leverage, but they will not budge, and if I pull any harder, I am afaid I will pull the car off the stands :bb
Doug
Re: New Brakes Question (DougTimme)
Those small bolts have Loctite on them and that can make them stubborn to break loose. Put a box wrench on them and give them a sharp smack with a hammer :smash: that shock load will usually break them loose.
For about the same money, I prefer the performance friction carbon metalic "Z" pad much better than the stock pads.
Doug
Doug--Just spring for the new rotors. You're right.......GM spec call out is not to turn the rotors. They are use and trash parts. But the three times I took mine in for warranty complaints of warped rotors (pulsating pedal), the dealer, yep, turned the rotors and did not replace. So, during my 30k mile service, I replaced the rotors with DBA drilled & slotted and Delco ceramic pads. The bolts you're talking about.................had to use a breaker bar.
:thumbs:
I think that you are talking about the bolts that hold the caliper housing to the rotors. They are on with 130 ft lbs of torque. The caliper bolts are the 23 ft lbs of torque and your wife can take those off. You need to eat your wheaties with those other bolts! I had a hell of a time changing over to the eradispeeds but it can be done. You need alot of swing room for the wrench so put the car high as you can on the jack stands and just remember to be SAFE! 'Dem bolts are a muddah! :crazy:
When you are working with the rotors make sure they fit on the hub correctly. Check the hub for a ring of rust right where the rotor fits around it. You want to make sure there is nothing that will keep the rotor from sitting flush against the hub flange. When you put the wheels on make sure you put the lug nuts on so the wheels are flush against the hub. Then torque them to 100 lb ft. As for replacing the rotors, if it was me and the rotors aren't scored I would throw a new set of stock pads on it and go out and burnish them in. Then after letting the car set for several hours go out and abuse them a little. I have beat the hell out of stock rotors and pads and have never had a warped rotor.
Bill
