New rear tires time...
Old Jul 29, 2025 | 05:51 PM
grinder11's Avatar
grinder11
Default New rear tires time...
Has anyone here tried the Toyo Proxes TQ streetable drag radials? They look good, and have good specs, except they are a bit porky at 32lbs for the 315-30-18 size.....
Old Jul 29, 2025 | 06:31 PM
lucky131969's Avatar
lucky131969
I looked at those last summer when I replaced my MT ET Streets in that size. I ended up going with Nitto NT555RII in 305-35-18.
Old Jul 30, 2025 | 08:48 PM
Beast's Avatar
Beast
Nitto drag radials worked for me, I finally tried mine on the street. I don’t have the power you got. 340 wheel horse, yank3200, and 3.73 gears, no times, but was just messing around in Mexico. I was able to brake stall the converter to 2,000RPM, I didn’t try any higher then that, treated the gas pedal like an on/off switch and it worked really well after the tires warmed up a bit. I hear the nittos have a stiffer side wall then other drag radials, and would probably be better if your street driving. I hear the back end walks with M/T ET streets.
never tried Toyo’s
Old Jul 30, 2025 | 11:55 PM
Ltngdrvr's Avatar
Ltngdrvr
I've seen nothing but positive reviews for the TQ's.
They are what I will eventually be going with for track times.
To New rear tires time...
