EBCM FIXED 1 code left
Old Aug 1, 2025 | 10:20 AM
Woopigsooie00's Avatar
Woopigsooie00
Default EBCM FIXED 1 code left
Just got my ebcm back from ABS fixer and my code u1040 and p1657 are gone but now I have a TCS c1218 H C
When i reset the codes on the dic, I can feel the brake pressure change.
comments on my order were:
12 Codes in history. Previous repair by others. Excessive solder applied to daughter board causing shorts to case. Removed excessive solder. Reflowed. Repaired solenoid relay control circuit. Repaired pump control circuit. Added surge suppression. Cleared all all codes. Tested. Could not reproduce faults. Codes in history. C1218, C1232, C1241, C1254, C1255, C1282, C1283, C1284, C1286, C1287, C1288, C1296. If C128X codes and C1296 code returns, check for shorted brake pressure sensor or vehicle attitude sensor.
Module OK.
So since they couldnt get any codes to show im guessing its got to be on my end.
Old Aug 1, 2025 | 11:51 AM
Dads2kconvertible's Avatar
Dads2kconvertible
What car?
Old Aug 1, 2025 | 01:58 PM
Woopigsooie00
2001 corvette
Old Aug 1, 2025 | 04:26 PM
Cesar@TPS's Avatar
Cesar@TPS
Supporting Vendor
Could actually be the pump that is built in to the abs, was everything re-installed correctly ?
Old Aug 1, 2025 | 06:57 PM
Woopigsooie00
Yes ebcm was put back on. Screwed in and both plugs plugged in. Nothing else on the unit was removed
Old Aug 1, 2025 | 07:08 PM
lucky131969's Avatar
lucky131969
Why not just follow the troubleshooting procedure?
File Type: pdf
To EBCM FIXED 1 code left
