C5 Clutch Issue – High Bite Point, No Modulation
Over the winter, I noticed a sudden change in clutch behavior. The clutch began engaging abruptly at the top of the pedal travel. The engagement window is basically non-existent — the clutch grabs quickly and harshly right as the pedal nears the top, making smooth engagement difficult and sometimes causing a shudder.
Around the same time, shifts became slightly tougher. There’s more resistance going into gear, and I’ve noticed a faint clunk and some roll when engaging first, like slack is being taken up late.
Despite this, the clutch holds strong under load. I do occasional street driving and autocross, but I don’t abuse the clutch. Starts are usually rolling—not dumped from high RPM. There’s no slip, even under WOT in 4th at 20 mph. Given that and the mileage, I don’t think the clutch is worn.
I suspected a hydraulic issue and replaced the master with a Tick Performance unit. I’m using ATE Typ 200 brake fluid for its high boiling point. Bleeding was done with the master installed and connected to the pedal. I had someone pump the clutch while I held open the GM quick-connect at the end of the master line (before connecting it to the slave), letting fluid and air purge. That seemed to handle the master side, but the issue remains.
The Tick pedal feels fine overall. I adjusted it at the rod per their instructions, though it was tough to dial in—likely due to the state of the system. The clutch pedal sits about 1.5 to 2 inches closer to the firewall than the brake pedal.
The car isn’t on its original clutch. At 54,000 miles, a prior owner had a full clutch job done at a local transmission shop. The receipt lists a GM clutch, pressure plate, and flywheel, along with a new slave, throwout bearing, and pilot bearing. No remote bleeder was installed. I have one on the shelf, but I’d prefer not to drop the drivetrain unless I have to.
Here’s where I’m at:
- Could this still be a hydraulic issue—air trapped in the slave limiting travel?
- Could this be a mechanical issue, like weak or worn pressure plate fingers, even though the disc grabs fine?
- Is it possible the clutch is still holding, but these are early signs of failure?
Also, is there any way to install a remote bleeder with the drivetrain still in the car? I doubt it, but figured I’d ask.
At this point, I'm debating whether to keep troubleshooting or prep for a full tear-down: clutch, slave, torque tube refresh, and everything that comes with it.
Thanks in advance for any insight.
If the clutch assembly itself is the problem, I’m wondering which part is failing: worn pressure plate fingers, release mechanism issues, something along those lines. I’m still trying to figure out if this is a hydraulic problem (like air in the slave) or a mechanical problem somewhere in the clutch system that isn’t the disc itself.
I’m open to the possibility that the clutch assembly is the issue, but I want to understand the likely failure mode before committing to what is one of the most labor-intensive clutch jobs to do. I’m still hoping this turns out to be a hydraulic problem that can be resolved with a proper slave bleed, which is something I have yet to perform.
However, it is worth noting that the problem behavior existed with the old master and the new master so I don't think the lack of bleeding at the slave caused the issue. But at the end of the day air/moisture could still be trapped in the slave.
ATE Typ 200 is compatible to DOT 3&4, so you're ok there.
The high engagement could point to a worn disk (unlikely...as you describe), worn throwout bearing, damaged pressure plate fingers or master cylinder linkage out of adjustment.
You mention the pedal sit lower to floor than brake pedal. Did you adjust the rod the wrong way? If you shortened the linkage it would cause a lot of the problems you're seeing. Maybe you adjusted it with the linkage not fully engaged in the MC piston, like the rod sitting on the side of a pocket instead of bedded in the middle? That could account for the sudden change in adjustment.
Wish I had more, but maybe will help you narrow things down a bit.
No sense in anyone speculating on anything until you bleed the system. Put a remote bleeder in while your down there.
Is it possible to install a remote bleeder with the drivetrain in the car? I asked this in my original post but no one has chimed in on it. I actually have one on the shelf.
I've only found one set of instructions (a YT video) of someone accessing the bleed screw on the slave. I haven't had any luck searching the forums to see if anyone's removed it and added the remote bleeder. I thought I read once that someone said it's risky or challenging because of how recessed the bleeder threads are.
The linkage is definitely not adjusted perfectly, but I do not think it is the root cause. I found the Tick instructions a little vague. In my car, with the clutch system as it is now, shortening the rod (bringing the pedal closer to the firewall) caused only a very slight creep. Per the instructions, you then lengthen the rod until the creep goes away and it shifts well. When I did that, the pedal ended up with about half the travel of the factory setup. I assumed this was because there is something wrong with my car and not something that is expected. They also warn that lengthening the rod too much can overextend the pressure plate and cause damage, so I erred on the side of caution and did not go too far.
I think I do need to lengthen it more, as the clutch pedal currently sits about 1.5 to 2 inches lower than the brake pedal. Even when I had it adjusted a little longer than it is now, I did not notice any real change in the bite point or engagement window. Only the overall stroke length of the pedal changed.
