Help; C5z diff installing c6z output shafts
Old Aug 13, 2025 | 08:59 PM
zblkr1's Avatar
zblkr1
Default Help; C5z diff installing c6z output shafts
I am in the middle of changing out both output shafts on my c5z diff. I broke the common LH. I bought c6z LH and RH to do both. I am in the middle of installing the RH output shaft. The original design from the c5z is a 1 piece and the c6z is a 2 piece with a snap ring. When installing the RH I noticed the c6z sticks out further causing issues with getting the spider gear shaft back in because it contacting the end of the shaft
am I doing something wrong? What am I missing.
thanks
Old Aug 13, 2025 | 11:13 PM
CFight's Avatar
CFight
Not sure what you got and haven't swapped mine. This might be required?
https://www.zip-corvette.com/97-13-differential-heavy-duty-rh-axle-shaft-gear-upgrade.html?srsltid=AfmBOopOgqzYJgxD-axVnVcriBfna5I3J7qcZFnnW-wqC2ClHOGrfbUe
https://www.corvetteforum.com/forums/c5-tech/2547887-output-shaft-install-left-and-right.html
Old Aug 14, 2025 | 08:52 AM
zblkr1's Avatar
zblkr1
i have that, I will upload some photos later.
Old Aug 14, 2025 | 03:35 PM
zblkr1's Avatar
zblkr1
Rick@RKT helped me out, thanks guys. You can close it down.
Old Aug 14, 2025 | 04:16 PM
MetalMan2's Avatar
MetalMan2
Is your resolution worth sharing with the rest of us? For "posterity", perhaps.
Old Aug 15, 2025 | 06:50 AM
zblkr1's Avatar
zblkr1
There is a U shape tool that compresses the clutch spring under the side gear. You will need that tool to compress the spring in order to install the cross pin. The updated part adds more pressure compared to the original.
To Help; C5z diff installing c6z output shafts
