Cheapest tech 2 to bleed brakes
Old Aug 14, 2025 | 07:35 AM
Woopigsooie00's Avatar
Woopigsooie00
Default Cheapest tech 2 to bleed brakes
2001 vert
I had my ebcm repaired, and think my pump relay is shot because i cant seem to fix code c1218. I got a wworking pump and am ready to swap it.
What is the cheapest tech 2 that will bleed the brakes?
seems like it will be alot easier to use than the old fashion way.
Old Aug 14, 2025 | 08:21 AM
lucky131969's Avatar
lucky131969
Originally Posted by Woopigsooie00
2001 vert
There are no real Tech2 that fall into the cheap category. The chinese Tech2 copies are around $400. There may be some scanners that have the ability to activate the pump.
What relay are you referring to?
Old Aug 14, 2025 | 08:35 AM
Supercharged111's Avatar
Supercharged111
I believe the brains can be bolted on without cracking a brake line loose?
Old Aug 14, 2025 | 10:12 AM
Woopigsooie00
I said relay but im meaning the motor circuit of the bmpv. I have followed the FSM and it leads to needing to replace the bmpv. Ebcm is rebuilt like new from absfixer.
Old Aug 14, 2025 | 10:13 AM
Woopigsooie00
im doing the bmpv not the ebcm.
Old Aug 14, 2025 | 10:20 AM
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
I just did it with a
Autel 808s Autel 808s
and it made a big difference
Looks like this
one for $178 one for $178
can do it too
Old Aug 14, 2025 | 10:57 AM
lucky131969
Ok.
Old Aug 14, 2025 | 01:10 PM
belmor's Avatar
belmor
Tech2Win is a Tech 2 emulator. You can buy the adapter for around $100 and it works well but you have to be pretty-tech savvy and patient to configure it.
I was having issues with my ABS pump being frozen (ended up being bad) and this scanner worked fine on it for $120.
Amazon Amazon
~B~
Old Aug 14, 2025 | 01:13 PM
99FRC Newb's Avatar
99FRC Newb
Where are you located? If you are near Raleigh, NC, you can use mine.
Old Aug 14, 2025 | 07:14 PM
don37's Avatar
don37
Veteran: Canadian Forces
yes
To Cheapest tech 2 to bleed brakes
