Supercharger questions
1) In general, to what degree do superchargers decrease engine life. I assume they will increase wear substantially, but is this true, and to what degree ?
2) What are the best superchargers for the LS1 ?
3) What additional modifications are necessary after supercharging ? New wheels, tires, transmission ?
Thanks,
:flag
Second, there are really three C5 SC choices:
a. ATI Procharger (7psi - 535hp on stock C5)
b. Vortech (7psi - 535hp on stock C5)
c. Magnusun (5psi - 490hp on stock C5)
Third, with the ATI or Vortech you wouldn't have to make any additional changes. Both of these kits are complete. The Magnussun SC requires a high-rise hood. Oops, I forgot. . .you should plan to have the car dyno tuned at a reputable tuner regardless of your choice.
I chose the ATI. It is twin-intercooled. . .Vortech is aftercooled and Mag. is not cooled! However, all systems are very nice. I don't think you could make a wrong choice. :cheers: :cheers:
The ones that seem to be getting the most press right now are the ATI and the Magnacharger. The former is a centrifugal one that can be coupled with an intercooler, whereas the latter is a roots type and presently, on the C5, is not intercooled -- it also requires an aftermarket hood due to its height, whereas the ATI does not. Each has pros and cons, but the ATI will permit higher peak boost and, hence, more HP/tq, whereas the Magna seems to produce greater #s in the lower RPM band. Also, at some point, and also under debate, is that if your HP/tq is too high, it considerably raises the chance of killing a stock bottom end. Also, the ATI initially went thru some real bumps as far as the kit goes, whereas there have been far fewer reported problems with the Magna. Most of the ATI problems, however, appear to be resolved.
Hope that's a start for ya. :seeya
1) Can you please provide a link for an ATI vendor ?
2) What exactly does intercooling mean ?
Thanks,
:seeya
They just sent me a whole bunch of shiny parts that are going to make my car faster.:D
Look under supporting vendors for "East Coast Supercharging".
[Modified by Fastguy, 10:13 PM 2/16/2003]
The ATI procharger is what interests me most, I definitely don't want to get a new hood. How much is the ATI bought and installed ? I checked out the links above, and prices were difficult to assess.
Thanks for the tip of the forced induction section, there is a lot a good info there. After beating around this place for so long, some places you just don't see until they are pointed out.
I would really love to check out the ATI system if anyone here has one in the Memphis area ? I don't like getting passed over by 911 Turbos (actually happened once), this seems to be the solution.
:flag :yesnod:
[Modified by Spiral Bri, 1:13 PM 2/17/2003]
