Shake/Shudder above 60MPH
Old Sep 1, 2025 | 08:14 PM
Vox Machina's Avatar
Vox Machina
Default Shake/Shudder above 60MPH
Well continuing the saga of random issues with my C5... it has developed a shudder above 60MPH when on throttle. It is throughout the entire chassis, though I can particularly feel it in the shifter and through the driveline. If I let off the throttle or throw it into neutral the shake in the shifter is gone, though there's still some vibration in the chassis.
I had all 4 wheels rebalanced as I figured it was the easiest variable to eliminate. Shop said they were off by a hair but not enough to cause what I'm talking about. Some guys I spoke with think it's the TT couplers, which given that it goes away if I'm off the throttle/put it into neutral isn't outside the realm of possibility, but I would have expected to feel it across certain RPM ranges, not above certain speeds.
I'm at a loss though, barring either some really bad wheel bearings or a half-shaft that somehow got way out of balance I can't imagine anything else causing this. Any ideas before I yank the TT out (again)?
Old Sep 3, 2025 | 09:40 PM
Vox Machina
Anybody?
Old Sep 3, 2025 | 10:52 PM
lucky131969's Avatar
lucky131969
At least tell the whole story. This is not just a random event that happened to your daily driver. This is salvage car with major suspension damaged that you have pieced together.
https://www.corvetteforum.com/forums...n-project.html
Old Oct 2, 2025 | 04:42 PM
Vox Machina
So an update.
Some people on FB suggested that it was an issue with the TT and/or the couplers. Just pulled it and I see no glaringly obvious issues there. Barring the driveshaft somehow bending or somehow magically becoming unbalanced I don't think that's the cause. Going to have the shaft balanced anyway just for peace of mind (might replace the couplers as well since it's apart).
Once I get it back together, I'm going to throw a buddy's set of wheels on the car just to eliminate the wheels as a possibility in their entirety. Only thing of note is that the rear drivers side wheel has a fair bit more weight on it than the rest of the wheels (4.25oz vs the rest at 1-2oz) but not a crazy amount.
The issue does happen in all gears so I don't think it's the transmission. Barring some weird issue with the diff I'm at a loss.
Old Oct 2, 2025 | 10:31 PM
Spartanfan23's Avatar
Spartanfan23
I assume you have had a 4 wheel alignment with a road force machine.
Old Nov 14, 2025 | 07:40 AM
Vox Machina
Another update.
I didn't want to post until I had confirmed the fix. When I pulled the TT apart and did the couplers, I decided I was going to have the DS balanced, just as a CYA thing. Turns out it's a good thing I did, as the shop I took it to said the DS was bent pretty badly. They were able to straighten it out and rebalance it however. After some futzing with my clutch speed bleeder (I have become a master at stabbing the TT in now) I took it for a test drive yesterday. Vibration appears to be gone! Held it at 61 (where it was at its worst) and nothing but smooth sailing.
The real question is, how tf did the DS get bent? I had the shop check the TT just in case and they said it was spot on.
Old Nov 19, 2025 | 06:56 PM
nitromainia's Avatar
nitromainia
Originally Posted by Vox Machina
Another update.
Pulling mine for the same situation
Not tire balance
Not anything obvious. Just the under load mild but annoying shudder
No load ....goes away
Thanks for Posting
Old Jan 9, 2026 | 10:52 AM
Car.guy's Avatar
Car.guy
My 2016 with 33k miles had a shudder on light acceleration about 60mph and it turned out to be the transmission. It felt like I was driving over a wash board. We did the GM TSB triple flush and it seems to have fixed the problem. Not cheap at the dealership but I was glad it solved the problem.
Old Jan 9, 2026 | 06:39 PM
Beast's Avatar
Beast
That’s a C7 thingy, your in the C5 section. And, IMO, the triple flush is a band aide. Your problem is still there. There are some write ups out there on this. Good luck with your C7. Here’s what I heard from a transmission guy. The AFM or DOD, whatever it’s called, puts pressure on the cheap torque converters, torque converter breaks overtime, pieces fly into the transmission and now it’s broke. You need to have the cam and lifters replaced, get the DOD or AFM tuned out, get a Yank converter, then hopefully the transmission will be okay after that.
Old Jan 9, 2026 | 07:02 PM
Car.guy's Avatar
Car.guy
Sorry for the intrusion....I didn't notice that I was in the C5 section. Yes, I've read a lot about the C7 trans issues and had I known that, I would have bought a C6 instead. Too late now so I'm going to buy the Range Disabler and keep my fingers crossed. It's hard to believe that after all these years GM hasn't been able to figure out how to build a reliable automatic transmission (and ENGINE!). Thanks for the input
To Shake/Shudder above 60MPH
