Power steering leak.
Old Sep 13, 2025 | 05:23 PM
rob-cyn's Avatar
rob-cyn
Default Power steering leak.
2000 FRC. Changed out the pump and o ring when I added a supercharger as I needed to go to a metal pulley. Had two o rings in it so far and it’s still leaking. Can someone confirm the actual GM part number for the o ring for the hard line that goes into the bottom of the pump. Also has anyone else ran into this and was it something else ? Starting to think it may be a defect on the pump as the old one never leaked. Thanks.
Old Sep 14, 2025 | 10:27 AM
helga203's Avatar
helga203
Yup that could be. Did many and never had an issue.
Old Sep 14, 2025 | 12:44 PM
rob-cyn's Avatar
rob-cyn
Did you but aftermarket pumps ? I looked at getting an OEM unit and its $750 ! Ouch !
Old Sep 14, 2025 | 12:47 PM
helga203's Avatar
helga203
Yes that dont cheap look what ur going through
To Power steering leak.
