PCM Relocation question
Old Oct 7, 2025 | 09:35 AM
99FRC Newb's Avatar
99FRC Newb
Default PCM Relocation question
How involved is the process to relocate it to the interior of the car?
I’m relocating the battery to the rear. I have the passenger fender off. Figured it is as good of a time as any to relocate the PCM.
Old Oct 7, 2025 | 10:26 AM
lucky131969's Avatar
lucky131969
What do you gain from relocating the PCM ?
Old Oct 8, 2025 | 07:26 PM
99FRC Newb's Avatar
99FRC Newb
Frees up space for a dry sump tank or UPP-style turbo kit in the future.
Old Oct 9, 2025 | 08:46 AM
mykream's Avatar
mykream
Should be enough harness to get it in the cabin on the passenger side.
Old Oct 9, 2025 | 09:53 AM
lucky131969
Gotcha.
Old Oct 9, 2025 | 11:31 PM
James Dean's Avatar
James Dean
It's honestly not too hard. You can easily tuck it up and into the passenger footwell. I'd recommend picking up a seam ripper from Amazon or a local crafts store for like $2 as it makes EASY work of cutting the tape on the wiring looms before you push them through the grommet. Might want to also add some tape to the lip of the grommet hole as the Fiberglass is occasionally sharp.
Here's a link to a 3D Printed PCM Holder as well
Old Oct 10, 2025 | 04:22 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
I like where your head is at. You're in the game here.
Old Oct 16, 2025 | 01:36 AM
NSFW's Avatar
NSFW
I moved mine to the passenger footwell to make room for a dry-sump oil tank. It was surprisingly easy, there's an enormous grommet in the perfect place to run the wiring harness back. The biggest drawback is that your passengers lose a couple inches of legroom. It doesn't sound like much but at 6'0" I'm glad I don't have to sit there. Fortunately my wife is 5'6".
If you have a 3D printer (or a friend with a printer) you can use my bracket: https://www.thingiverse.com/thing:7045026
Old Oct 16, 2025 | 12:44 PM
Tusc's Avatar
Tusc
If you don't mind, I added your file to the growing 3D objects thread.
Old Oct 16, 2025 | 04:12 PM
NSFW's Avatar
NSFW
Sounds great. I hadn't seen that thread before, thanks for letting me know it exists. Now I have some reading to do.
(I have mostly just been lurking in the track and tuning subforums.)
Old Oct 16, 2025 | 04:32 PM
Tusc's Avatar
Tusc
If you seek track chatter, absolutely find your way to FaceBook and the Corvette Track Enthusiasts page. Endless mods, parts, setup info.
Old Oct 16, 2025 | 06:17 PM
NSFW's Avatar
NSFW
I'm already there.
Old Oct 20, 2025 | 10:05 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Did you just put the PCM right on the carpeted kick panel in the footwell? I was thinking of hiding it, but I like this idea with your bracket. Its less clunky than the OE bracket.
Old Oct 21, 2025 | 12:38 AM
NSFW's Avatar
NSFW
Yes, it's bolted to the kick panel, and so is the TAC. I put another panel (actually a slightly trimmed cutting board) over them, and then put the floor mat back. Aesthetically it's all good, but I still need to make a spacer or standoff or something to hold the cutting board off of the PCM and TAC.
I used t-nuts on the pack of the kick panel, but I'm not sure that's the best idea. The kick panel plastic is a lot harder than I thought, so the t-nut prongs mostly just bent themselves flat. It works, I just had higher hopes. Riv-nuts might work better, but then the risk is that they don't bite and end up spinning.
Old Oct 21, 2025 | 10:26 PM
99FRC Newb's Avatar
99FRC Newb
Thank you! My friend had a 3D printer. I’ll ask him to make it for me.
To PCM Relocation question
