2002 Z06: HUD: No light inside
I have fixed the HUD pivot pin and replaced the bushing on the other side. Referred VettePros video to reinstall the mirror
After reassembling the HUD when I connected it to the car for testing, I was able to move the mirror all the way up & down. However, I didn't see the projection on the windshield. After spending a lot of time to check if I could see some some kind of light inside the unit, I can confirm I don't. I have looked in from outside of the car, there is no light on the VFD.
The windshield is HUD compatible because I see this printed on the windshield - bottom of the passenger side "SHADED HUD 4.8mm SOLAR RAY".
Considering, the mirror moves properly, there is no issue with the power.
Also, I have checked fuses 19 & 25, they are fine.
This doesn't look like the photo resistor issue as well.
So, is the VFD gone bad ? Some bad circuit, wire, etc. At this point, it could be anything.
I have no clue how to proceed and I am not that savvy in debugging electrical issues.
I am considering either buying a used one but inclined towards contacting ClusterFix and sending them my unit for repair if they agree. Because, even if I buy another one and if it fails as well, I will be back to square one.
Any help is appreciated.
Thank you!
