Torque tube surprise!
What I'm looking into now. No machine shops in my small town though. Looking for one in Vegas that will do it. I would really like to have the original spec to go by.
Any other performance transmission shops in the country? RPM can't be the only one. Any race series that has a lot of C5 running in it? A shop near one of those tracks probably sees more than an average amount of transmissions.
Blackjack Corvette Club is in the Las Vegas area, maybe someone there can point you to a local-ish place.
Same with Las Vegas Corvettes association.
I can't believe there isn't a service that specializes in this.
Corvette tax..
I know your hung up about the specs. I would be too, if I could find them. But in lieu of that I will take an engineer's educated guess over putting the worn out part back in all day, every day.
What is the problem here again? You chose to rebuild when it was ok but feel the yoke is off?
Number one - just call Jason at Texas Drivetrain please. These are dirt simple parts, not rocket science and $1000 anything involved with this is comically ridiculous unless you are ordering a DriveShaftShop couplerless brand new driveshaft.
12mm rebuild kit is $550 with a lot more parts than most of us need HERE at Texas Drivetrain Performance
The 10mm costs $125 more.
Labor to knock some bearings in and bolt on the new couplers and input shaft should be on the outside a 2 hour job from a billing shop. It's really one hour or less if you're handing them the torque tube. These are not rocket science parts. Hammer. Block of wood. Unbolt or unspring it, knock it out, unbolt the couplers, knock or press the bearings out, slap new ones on and reverse process.
In this case, it's obliviously not the bearing! Having specs would be interesting, but not that important.
As for the relative merits of having the old one repaired Vs sourcing a replacement... up to the owner.
I'd shop around for a used one, myself...
Good luck, and let us know how it comes out!
Edit:
Another option might be to find a bearing with the correct OD but smaller ID, and have the shaft turned down to match.
What tolerance? No specifics were given by SKF Engineer just obvious feedback that there should be a light press fit.
Hung up? Only because no measurements have been taken on the shaft to make an educated guess...... weighting that against the bearing tolerances. One bearing that should be a suitable cross reference for the the factory bearings is SKF 6008 2RSJEM. SKF has a great site with all the information you will ever need. https://www.skf.com/us/products/roll...-ball-bearings
I get where you're coming from. I really do. I would LOVE to have a design sheet that lists the specs for this part. But if I can't even get a reply from the OEM, I don't know where else to go. And it is glaringly obvious to me the hub itself is worn. I mean, the photo I posted above shows significant galling and an obvious lip where that inner race press fit. Sure, specs would be nice, but if you can see something is fkd up with the naked eye, I don't understand the pushback.
Edit:
I did consider the option of a smaller inside diameter although I didn't research it very much. Since the bearings are retained by snap rings, the amount that could be turned off the original hub would be pretty minimal to retain the grooves. Maybe there are bearings with an ID difference in the thousandths but I didn't bother checking.
At least now I have a name for the part. Interestingly, the part shown in your diagram is a different part number than the number the parts guy at the local Chevy dealer gave me.
