Confused DIC (tire pressure message)?
Old Feb 18, 2003 | 04:30 PM
Blue LS1-LT1's Avatar
Blue LS1-LT1
Default Confused DIC (tire pressure message)?
With my DIC, Driver Information Center, on my '99 coupe set to scroll through the Guages mode, the display showed the following two (2) messages after driving about 100 miles in 25 degree, dry, weather:
First message: "Service Tire Pressure Monitor System"
Second Message (about 5 minutes after the first): Rear L XXX R 32 psi
What would L XXX mean?
I checked for a "flat" in the Michelin Pilot Sport Run Flats...No problems.
after about 5-10 minutes, the display read Rear L 31 psi R 32 psi
all appeared normal.
there was no low tire pressure warning.
any advice would be appreicated!
Old Feb 18, 2003 | 04:34 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Default Re: Confused DIC (tire pressure message)? (adamschorr)
Left wheel sensor is acting up. Might be going bad or maybe because of the cold. Keep an eye on it. When it permanantly stops reading the pressure in that wheel (XXX) replace it.
Bob
Old Feb 18, 2003 | 09:24 PM
SAXN8R's Avatar
SAXN8R
The sensor is bad or has dirt plugging up the hole! This happened on mine and after dismounting the tire and blowing air in the sensor to clean the dirt out the problem went away.
To Confused DIC (tire pressure message)?
