C5 Preventative Maintenance Question
Serpentine Belt
AC Belt
Water Pump
Upper Radiator Hose
Idler Pulley
Harmonic Balancer
4 Tires
4 Rotors+pads
Driver side Window Regulator
Knock Sensors+harness(this is the next job on the list)
Check the Stickies. There's more, but the fluids will keep you busy for a while.
Good luck with your new-to-you C5.
You don't indicate if you do your own work. If you choose to have a shop flush your brake fluid, ensure they know you want the fluid flushed [with at least a liter of fluid] and not just the brakes bled.
The clutch hydraulics have a separate brake-fluid reservoir. If you don't have a remote bleeder for the clutch slave, consider installing one.
Serpentine Belt
AC Belt
Water Pump
Upper Radiator Hose
Idler Pulley
Harmonic Balancer
4 Tires
4 Rotors+pads
Do you have a backup car??
In the auto-repair industry, many techs will advise not messing with the ATF at 100k if there is no service history of prior changes. How did your mechanic determine that the fluid is "still good"?
