Fuel pump failure
Old Nov 23, 2025 | 03:32 PM
alssiri's Avatar
alssiri
Default Fuel pump failure
Hi, 01 Zo6 with 40k kilometers swaped rear diff & after that car started & drove it for a day & next day cranking no start & fuel pump not priming , checked & found that pump is dead & replaced it with GM 19421092 , car started & drove fine then next day again cracking no start , checked & found new pump dead again 🤦 .
Fuse & relay are OK, any reason may cause this or is it just new part failure?
Ahmad
Old Nov 24, 2025 | 08:09 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
How EXACTLY did you determine the pump was “dead” ??…maybe apply power and ground directly to the pump and if the pump runs it’s not the pump…how did you test the relay ??
Old Nov 24, 2025 | 12:48 PM
alssiri's Avatar
alssiri
1st pump was tested using a jumper then removed from the fuel tank & they tested it directly & it wasn't working, 2nd pump again the same procedure.
Old Nov 24, 2025 | 01:13 PM
C5 Diag's Avatar
C5 Diag
If you bought this pump from Amazon or EBay you can expect those results !!…now did you jumper from the battery directly to the pump or from the harness connector ??
Old Nov 25, 2025 | 12:05 AM
alssiri's Avatar
alssiri
it was from ebay but it is original GM , as per the mechanic they checked by jumper the relay & also directly to the pump harness.
Old Nov 25, 2025 | 12:22 AM
C5 Diag's Avatar
C5 Diag
If from EBay it’s probably counterfeit even if it says GM !!
Old Nov 25, 2025 | 06:27 AM
alssiri's Avatar
alssiri
Hmm just lasted for one day 😅 , i ordered one from rockauto.com (DELPHI - FG1213) will see how it goes .
Old Nov 25, 2025 | 06:43 AM
C5 Diag's Avatar
C5 Diag
Rock Auto is your best choice !!
Old Nov 25, 2025 | 11:21 AM
alssiri's Avatar
alssiri
Thought of Racetronix but decided to go with Delphi & hoping it will work fine 🙂
Old Nov 30, 2025 | 06:18 AM
alssiri's Avatar
alssiri
Delphi installed & working fine 🤞
Old Nov 30, 2025 | 04:05 PM
helga203's Avatar
helga203
I think your permaturee. Give it some time and report back. If it goes out you have a different problem. just saying. But what they say, 3rd a charm.
To Fuel pump failure
