differential swap
Old Dec 1, 2025 | 04:55 PM
Daveohio's Avatar
Daveohio
8th Gear
Default differential swap
Any know if an auto diff will swap with a manual diff. I know the gear ratio will be different but I'm planning to change that.
Old Dec 1, 2025 | 05:06 PM
lucky131969's Avatar
lucky131969
Get's discussed every other week.
https://www.corvetteforum.com/forums...ferential.html
Old Dec 1, 2025 | 05:30 PM
Daveohio's Avatar
Daveohio
8th Gear
Thanks, I should have researched it.
Old Dec 2, 2025 | 09:30 AM
Daveohio's Avatar
Daveohio
8th Gear
As an update rpm says to use an auto diff in a manual car you need to move the speed sensor and change the rotator inside. Not easy or cheap for the home tech.
Old Dec 2, 2025 | 10:30 AM
feeder82's Avatar
feeder82
The VSS is on the top passenger side of the diff. Auto or manual.
You need a tuner to change the pcm for the ratio change in a auto, and TCC slip tables and shift points need to be changed in the PCM to compensate for the gear change. the diff is a bolt in
Old Dec 2, 2025 | 10:52 AM
lucky131969
Who did you speak with at RPM? I have never heard any such thing. This is a very popular mod for the last 20 years. It would not be as popular if it required that level of intervention.
Old Dec 2, 2025 | 02:20 PM
RonSSNova's Avatar
RonSSNova
Most folks put the stick 3.42 diff into an auto car.
I believe he wishes a to get an auto trans diff, change the gears and put it in a stick car.
This is only viable with the 3.15 auto trans diff not the 2.73 diff.
Seems to be some things lost in translation here.
Old Dec 2, 2025 | 02:29 PM
Daveohio's Avatar
Daveohio
8th Gear
You are correct, diffs from auto cars are cheap and plentiful compared to manual cars. I was thinking if it would fit, I could build one from an auto car and just do a simple swap.
I'm still learning these cars. I did not know you need to start with a 3.15 to do the ratio change I was thinking about.
I sent a email to Camren at rpm and that was the answer I received.
Old Dec 2, 2025 | 02:42 PM
lucky131969
I completely misunderstood. In 18 years on the forum, I have never seen anyone that wanted to modify an auto differential intended for a manual car.
Good luck.
Old Dec 2, 2025 | 04:30 PM
grinder11's Avatar
grinder11
I am puzzled as to why the OP is doing this? If it is because the A4 diffs are more plentiful, and therefore somewhat cheaper, wouldn't you end up spending the same amount of $$$ in the long run? Assuming you want the 3.15 diff for the 3 series carrier, and are going to open it up to go with a 3.42, or lower gear? Say a 3.73 or??? I must be missing something. Yeah, that's what she said!!
Old Dec 3, 2025 | 09:42 AM
Daveohio's Avatar
Daveohio
8th Gear
I was thinking about changing the diff ratio in my manual car to 3.90 or 4.10. Not sure how I would like it or the amount of down time to change it. I didn't want it to be stuck on my friends lift for a long time. So, I noticed auto diffs are plentiful and cheap compared to manual diff. I'm also aware that the auto to manual swap is what is usually done.
So that was what was driving my inquire into the auto, manual swap.
Old Dec 3, 2025 | 10:14 AM
Daveohio's Avatar
Daveohio
8th Gear
Just to ad I got a 2nd email from rpm saying that if I had a 3.15 auto diff that switch is doable.
I was not trying to throw them under the bus.
Old Dec 3, 2025 | 11:09 AM
feeder82's Avatar
feeder82
Here's a very detailed thread on doing a gear change in the diff including the tools needed
https://www.corvetteforum.com/forums...ld-how-to.html
To differential swap
