C5 zo6 shift box alignment
Old Dec 4, 2025 | 09:11 PM
isaiah mitchell's Avatar
isaiah mitchell
6th Gear
Default C5 zo6 shift box alignment
Having trouble getting the neutral lock pin to push down. It is VERY stiff and currently sitting in penetrating oil. Any advice? Thanks you!
Old Dec 5, 2025 | 11:05 PM
RickZ06's Avatar
RickZ06
4th Gear
I had to use a punch and small hammer to get it to move fully in to place.
Old Dec 6, 2025 | 09:00 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
The pin is an alignment "gauge tool". It's purpose is to set the shifter, as it's installed in the shift box, into the true neutral position. If the pin doesn't easily drop into the alignment holes, then you need to loosen the clamp that holds the shifting rod in position, adjust the shaft that's in the shift box, so the alignment pin drops into place, then tighten the clamp back up.
Old Dec 6, 2025 | 08:01 PM
walleyejack's Avatar
walleyejack
check the other thread you posted about the same thing
Old Dec 6, 2025 | 10:11 PM
isaiah mitchell
6th Gear
Yeah, just got this and thought the first one didn’t post. Couldn’t figure out how to delete it. But regarding the pin and alignment, I did finally get it figured out.
To C5 zo6 shift box alignment
