Warning for those installing stainless brake lines.
Old Feb 19, 2003 | 12:54 PM
Blocktrdr's Avatar
Blocktrdr
Default Warning for those installing stainless brake lines.
When installing stainless brake lines in the rear make sure you check that you have not moved the solid factory line up against the driveline. I did not think about this and one of my lines was rubbing against the inner drive axle boot. It put a nice neat cut almost all the way around the boot and the lube sprayed out. I wouldn't have even seen it had I not been under there to wire my new fuel pump. It is not a cheap fix. The boot is $50, but the labor is about 4hrs.
