Traction Control and ABS
Old Dec 11, 2025 | 06:01 PM
dvender's Avatar
dvender
1st Gear
Default Traction Control and ABS
Hello, I was hoping someone could help me out. I have a 2003 vert 64K miles. Had the following codes and ABS as well as traction control lights come on. TCS C 1248 HC, TCS C 1254 HC, SDM U1040 HC and IPC U1040 HC, LDCM U1046, RDCM U1046 and PCM P1571. I had a tech recommend the ignition switch, which I replaced and that did remove LDCM U1046, RDCM U1046 and PCM 1571 but the other codes above remained. Thanks in advance for any insight.
Old Dec 13, 2025 | 03:48 PM
mmartinez's Avatar
mmartinez
Most Ignition switchs are made in China, and some of the contacts inside do not make up and send power to various systems. There is a sticky on this forum detailing how to repair Ignition switch contacts.
Old Dec 13, 2025 | 09:51 PM
Ltngdrvr's Avatar
Ltngdrvr
Where is this sticky?
Old Dec 13, 2025 | 10:19 PM
Smoken1's Avatar
Smoken1
The DYI thread above
Old Dec 14, 2025 | 10:54 AM
Gordy M's Avatar
Gordy M
Here it is
File Type: docx
To Traction Control and ABS
