LS1 driveline into Z06 shell?
Old Dec 17, 2025 | 11:48 AM
FFWD's Avatar
FFWD
6th Gear
Default LS1 driveline into Z06 shell?
I've been looking for an FRC and can't find any in my price range, but I did find a clean titled Z06 that was parted out, so it has no engine, torque tube, transmission, steering rack, suspension, brakes, or wheels. Other than the blasphemy, are there any parts incompatibilities stopping me from swapping in the entire driveline from a non-Z06 donor just to get up and running?
Popular Reply
Dec 17, 2025, 10:30 PM
arthursc2's Avatar
arthursc2
This forum and its constant obsession with resale value *eye roll*
**** is exhausting, give it break. If resale value is all you care about, y'all need to sell your cars today- before they depreciate further
Direct answer to the OPs question- yes an LS1 will be plug and play in your car. 99-04 Corvette motors will be a drop in swap, but you'll need it to be complete fuel rails to oil pan
any gen3 and gen4 LS based V8 will also "fit" but we'd need to walk you through specific changes depending on which gen motor you pick and what its accessories are
you could put a freakin 4.8 in there. It's your car! And a 4.8 powered Z06 is 1000% more fun than a stripped Z06 on jack stands
Party on brother
Old Dec 17, 2025 | 12:58 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
Preferably the donor vehicle should be the same model year as the Z06 or at least in the 2001 -2004 model years.
Old Dec 17, 2025 | 12:59 PM
mmartinez's Avatar
mmartinez
Shouldn't be any show stoppers, it will be more straightforward if the LS1 driveline is also a manual transmission. You won't have to contend with having to add a master cylinder, adding clutch pedal etc.
Old Dec 17, 2025 | 01:09 PM
FFWD's Avatar
FFWD
6th Gear
Makes sense. I was aiming for 2001+ for the updated torque tube design anyways.
Old Dec 17, 2025 | 01:12 PM
lucky131969's Avatar
lucky131969
No....you'll just have a sheep in wolf's clothing. Not sure why they would part out a ZO6 unless something about the frame or structure was not repairable, ex-flood, etc. In the end you may end up spending more to cobble it together....or you end up with a bastard-cat that no one wants. If you keep it forever no biggie.
Old Dec 17, 2025 | 01:13 PM
FFWD's Avatar
FFWD
6th Gear
Definitely going for manual.
Old Dec 17, 2025 | 05:04 PM
redzg's Avatar
redzg
So does the Z06 come with title? If so, normal or salvage? What kind of money — no need for specifics, just is it sufficiently below market to make it worth the effort?
Old Dec 17, 2025 | 10:17 PM
the_merv's Avatar
the_merv
Will the stuff fit from a 6spd Coupe, yes.
Depends on your budget and goals in the end of the day. I'd get everything Z06 correct in the car except the Engine, it'd be a 6.0l or 6.2. Don't waste the money on lesser option stuff that a Z06 would have had. No one would buy it.
Old Dec 17, 2025 | 10:30 PM
arthursc2's Avatar
arthursc2
Party on brother
Old Dec 17, 2025 | 10:34 PM
lucky131969
Party on brother
Old Dec 17, 2025 | 10:43 PM
the_merv's Avatar
the_merv
Party on brother
So you'd be the pinecone with a 4.8l in a C5Z06.. got it..
Old Dec 18, 2025 | 01:19 AM
FFWD's Avatar
FFWD
6th Gear
Normal/clean title. We can't plate any branded titles here, so that's the first thing I checked. It should come out less than any base model selling around here, but even if it's the same or more, I'd be OK with that for the Z06/FRC body with the lighter glass and rear brake ducts. The amount of work I'll be doing to put this together is actually part of the fun. I really wanted a project and had considered a C3 restomod or a Factory Five Roadster build, but both of those are long term projects and costs can get out of hand quickly.
Old Dec 18, 2025 | 07:24 AM
arthursc2's Avatar
arthursc2
I have an iron block 408 Z, but if the options were A) No Z or B) 4.8 Z? Taking the 4.8 car all day
some proverb about wishing and shitting in hands
Old Dec 18, 2025 | 07:40 AM
redzg's Avatar
redzg
Sounds like you’ve done your homework and have a path plan. Excellent, and more power to you. As you and others above have alluded, don’t let ‘perfect’ get in the way of fun. The numerous project cars I see in my normal travels that sit in garages and driveways slowing turning into dust is heartbreaking.
Old Dec 18, 2025 | 08:40 AM
Supercharged111's Avatar
Supercharged111
Slap a Wuhan Whirly Boi on that 4.8 and people will start shutting up real quick.
Old Dec 18, 2025 | 12:11 PM
the_merv's Avatar
the_merv
That's the only way a 4.8l would go in anything I own. I'm not wasting the time to cram in that small of an Engine in a car to eventually pull it out in the future for what needs to go in there or bigger.
I didn't think I would have to elaborate that common sense but some people in here need that broken down. "4.8l or jack stands party on BROTHER"..comical.
I'm over here with a couple different cars to drive, not jackstandistan.. I can take my time to build what I want but thanks for telling me what MY options are.
Old Dec 18, 2025 | 01:40 PM
arthursc2's Avatar
arthursc2
Great! That's wonderful for you!
a) this isn't your thread, go start one of your own to tell us all about your project
b) suggesting a 4.8 was just an example to demonstrate the interchangeability of LS motors
you can also do whatever you want *shrug*
party on brother
To LS1 driveline into Z06 shell?
Old Dec 18, 2025 | 01:44 PM
the_merv's Avatar
the_merv
I have a few threads, thanks for the advice tho you're a sweetie.
Old Dec 18, 2025 | 01:47 PM
arthursc2's Avatar
arthursc2
Your mom calls me sweetie too! Kindness runs in the family
Old Dec 18, 2025 | 02:30 PM
the_merv's Avatar
the_merv
Ahh there's the high school level "your mom" joke from the high school level maturity. I was waiting for it, I knew it was there and you came through with it. You win the intellect award for the day. Go eat your crayons now run along..
