C5 Shifter
Old Dec 20, 2025 | 01:57 PM
C5Caleb's Avatar
C5Caleb
2nd Gear
Default C5 Shifter
This is my first time on this website. After plenty of research, last night I disassembled my center console in my c5 (base), took the shifter out and put grease onto the rod inside the shifter and around the rubber parts of it. I didnt expect it to work as well as it did.
To preface this, shifting through the gears before this was a little tough, especially putting and securing it into reverse.
if you’re having issues like I was I would completely recommend doing this.
you do not need a bunch of grease, and I used a synthetic brake and caliper grease with temp ratings of -40 to 490f.
Old Dec 20, 2025 | 10:37 PM
jdmvette's Avatar
jdmvette
Night Owl for life
welcome to the forum.
i got my c5 in my twenties too
Old Dec 21, 2025 | 03:15 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Sounds like a good start.
Old Dec 21, 2025 | 09:11 AM
C5Caleb's Avatar
C5Caleb
2nd Gear
thanks! I absolutely love it
Old Dec 21, 2025 | 08:58 PM
USAZR1's Avatar
USAZR1
Welcome aboard, Caleb.
Old Dec 21, 2025 | 09:13 PM
c6miller's Avatar
c6miller
You can also adjust the shifter which will help make it shift better. There are a few you tube videos on how to do it. Peter
Old Dec 21, 2025 | 09:17 PM
Tusc's Avatar
Tusc
In my head I am tempted to put a yt video out on this. Many touch on it but have maybe serviced the shifter two or three times. I've done it an easy two dozen or more between my own cars or for others and while the simple explanation works well I think the right visuals can aid guys in understanding the alignment needs better. Also the differences when various parts are mixed.
Old Dec 21, 2025 | 10:29 PM
walleyejack's Avatar
walleyejack
am thinking the synthetic grease that one uses on the rubber seals around the doors and such, would work as good as any i think.
Old Dec 21, 2025 | 10:31 PM
Moved to C5 Tech.
Old Dec 22, 2025 | 06:52 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Hey thanks for your post and welcome to the Forum. Great spot to learn and discuss all things Corvette. Don’t forget the 👋
To C5 Shifter
