High idle/Won’t start
Old Dec 22, 2025 | 08:14 AM
MoPops48's Avatar
MoPops48
7th Gear
Default High idle/Won’t start
2000 with 15,000 miles and no previous issues. On cold start immediately idled to 2500+ rpm, continuously. I shut it down and then it turns over but won’t start. No codes. Any ideas what it could be?
Old Dec 22, 2025 | 08:49 AM
lucky131969's Avatar
lucky131969
How did you check for codes? Will you be doing the repairs yourself? Do you have a test light, DMM, and a fuel pressure gauge to connect at the fuel rail?
Old Dec 22, 2025 | 10:33 AM
MoPops48's Avatar
MoPops48
7th Gear
I checked codes DIC codes by holding down “options” then cycling through that process. I’m not going to do the work myself, I was just hoping to have some idea what the problem might be before taking it to a shop. Thanks!
Old Dec 22, 2025 | 12:38 PM
mmartinez's Avatar
mmartinez
From the original high idle problem I am guessing that there is some problem with either the PCM and or the TAC module. Both modules reside under the battery tray and are accessible by removing passenger tire and unbolting a cover. The car not starting is either due to no spark or no fuel.
Old Dec 22, 2025 | 08:05 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
If no Tach movement during cranking it may be a faulty crank sensor...you will not have spark or injector pulse...you can try spraying an alternate fuel like Brake Kleen into the engine and if it starts momentarily you have a fuel delivery issue.
Old Dec 24, 2025 | 10:04 PM
Missileboy's Avatar
Missileboy
High idle could be caused by a vacuum leak or possibly a MAF issue. My MAF failed and threw a code "MAF high voltage out of range" or something to that effect. Didn't trip CEL but did drop a code and caused high idle. I was having a heck of a time getting my O2's to set for emission test and that is how I found the issue trouble shooting the O2's. Not saying this is related to the no start issue, just possible high idle causes.
To High idle/Won’t start
