Suspension Upgrade
Old Feb 19, 2003 | 07:14 PM
TheBigDog's Avatar
TheBigDog
Default Suspension Upgrade
I am planning on upgrading my suspension with ZO6 sway bars and Bilstien Sport Shocks. Is it necessary to dop a 4 wheel alignment after the install?
Thanks for the info :cheers:
The Big Dog
Old Feb 19, 2003 | 07:28 PM
davidfarmer's Avatar
davidfarmer
Default Re: Suspension Upgrade (TheBigDog)
no. As long as the ride height stays the same, you should be OK. However, it might be a good idea just the make sure it was aligned right to begin with.
Dave
Old Feb 19, 2003 | 11:37 PM
C5stein's Avatar
0C5stein
Former Vendor
Default Re: Suspension Upgrade (davidfarmer)
:iagree: with David
As long as the ride height stays the same and you don't disconnect or move any of the suspension mounting bolts, then you are okay if the car is in alignment now.
Sometimes the gas shocks are a bit difficult to get out. The best way that I have found is to disconnect the sway bars, jack up (compress) the suspension. Safety wire the shock in the fully compressed condition, then unbolt, then allow the suspension to droop. The shock will almost fall out. I do the same in reverse to put the new ones in.
The job becomes much easier.
Old Feb 20, 2003 | 09:10 AM
UtahVince's Avatar
UtahVince
I did the same work on my 98 coupe about three years ago. No need for an alignment.
To Suspension Upgrade
