Jacking pucks......
Old Jan 6, 2026 | 01:19 PM
grinder11's Avatar
grinder11
Default Jacking pucks......
Is there anyone here who leaves their lifting pucks in at all times? If so, what brand and where did you buy them? I need to buy 4 new ones. I made up some nice ones in the Toolroom before I retired. But last October, around 5:00A.M. just N of Cincinnati, Ohio, I hit something on I-75 Southbound. Never saw it. Did some damage underneath the car. Damn lowlifes who do **** like this shouldn't even be hauling an empty trailer, much less a loaded one!! This encounter also resulted in ripping one of my "permanent" pucks right out of the undercarriage. Since it was a custom machined item, I'll have to replace all 4 so the vehicle sits level on my lift. Any suggestions? Thanks, guys......
Old Jan 6, 2026 | 01:39 PM
lucky131969's Avatar
lucky131969
I remember seeing snap-in plastic ones years ago. I have machined pucks, but never considered leaving them in all the time. I always carried one in my rear storage just in case I had to get one wheel off the ground for a repair.
Old Jan 6, 2026 | 02:41 PM
Ltngdrvr's Avatar
Ltngdrvr
When I bought my car it came with those snap-in plastic jack pucks, I guess they work but haven't used them, and they stay in the hole okay, although I would wish them to be taller.
But, when I made up my travel spare tire kit and got a scissor jack to go with it, I fixed up a stud in the lift cradle of the jack to stick up in the factory hole at the jack point, so if I jack the car up with that, I will have to take the pucks out of the holes.
Now, as to where to get those snap-in pucks, never searched for them so don't know of a source.
But, there are lots of ready made choices on the market for aluminum ones.
Old Jan 6, 2026 | 02:57 PM
chasboy's Avatar
chasboy
Oldtimer
My new set of leave-in plastic ones are arriving soon. I looked at the aluminum ones but I have reservations.
Old Jan 6, 2026 | 03:04 PM
Fast one's Avatar
Fast one
I made a long rail out of 3/4" x 1.5" aluminum for each side with the leading edges tapered up, they've held up very well for a lot of miles and 18 years. There are commercial ones for a C5, https://www.c6performance.net/catalo...-p-485788.html.
Old Jan 6, 2026 | 05:50 PM
chasboy's Avatar
chasboy
Oldtimer
Fast one, those are pretty impressive. Wish I knew about them before!
Old Jan 6, 2026 | 06:26 PM
redzg's Avatar
redzg
I went with chinesium CNC machined anodized aluminum from Amazon. Ludicrously inexpensive, and slightly guilty, but well made and holding in place quite well:
Amazon Amazon
Old Jan 6, 2026 | 06:55 PM
pjdbm's Avatar
pjdbm
https://www.amazon.com/gp/aw/d/B095C...7-6868ebf63513
Those are the ones I bought, but in black
I like them, was tired of using hockey pucks.............
Old Jan 6, 2026 | 09:43 PM
bluehighwayflyer's Avatar
bluehighwayflyer
I’ve got four aluminum pucks permanently installed as well. Mine were made by a company called “Samman”.
Old Jan 7, 2026 | 03:38 AM
vette4fl's Avatar
vette4fl
On Amazon. Stay-in aluminum and a couple rubber selection
Old Jan 7, 2026 | 10:24 AM
MetalMan2's Avatar
MetalMan2
Mine has plastic snap-in ones that have been in place for over 7 years.
Amazon Amazon
But at $39 now (I had paid $46!) I'd just get the cheap aluminum ones above... especially the red which will be more visible while lifting the car.
Old Jan 7, 2026 | 10:37 AM
sonata2.0T's Avatar
sonata2.0T
I tried the bolt in ones but they are too thin, I use the thicker rubber ones I keep in the trunk.
Old Jan 8, 2026 | 10:54 AM
grinder11's Avatar
grinder11
Thank you, guys....
Old Jan 8, 2026 | 11:01 AM
ariZona06's Avatar
ariZona06
ZL1 ADDONS. I purchased these several years ago. A bit of blue Loctite on the fasteners and they've stayed in place for many track days. They work great with the Quickjack too.
Old Jan 8, 2026 | 04:04 PM
TheBac's Avatar
TheBac
I think pucks were the first thing I bought after I got my car in 2018.
These are what I bought.
Amazon Amazon
They're still there, 10000 miles later.
Old Jan 8, 2026 | 05:10 PM
MetalMan2's Avatar
MetalMan2
These are what I bought. https://www.amazon.com/dp/B00XXD32R4
Same ones I mentioned above also since 2018, but for 27k miles
Old Jan 9, 2026 | 09:00 AM
Gordy M's Avatar
Gordy M
I have had my on since 2004, back then they only ones that fit were BMW 36 series pucks of a hard rubber compound. I autocross and HPDE my car and change tires/wheels brake pads/oil thousands of times since jacking up on those pucks. They are still on the car
To Jacking pucks......
Old Jan 9, 2026 | 09:11 AM
lucky131969
Can't believe this thread is still going.......for puck's sake!
Old Jan 9, 2026 | 10:16 AM
WindHam's Avatar
WindHam
I just use a piece of 2x4 wood to keep the jack stands from marring the paint on the frame. Racing jack just goes in raw because there is no room to put anything in between. Car scrapes over everything anyways ¯\_(ツ)_/¯
Old Jan 9, 2026 | 11:15 AM
lucky131969
So you jack it up on the painted rocker covers?
