Hi all, was wondering if anyone here happens to know what the part number is for a 1997-1998 manual rear ABS non f45 transmission harness is? Wasn't able to find definitive answers online, thanks
but i am also seeing 12189908 and 12189909 as front mounted ABS harnesses (i need rear). also whats the difference in the harness between a export and non export (CODE VD1)
Hopefully others will chime in with more knowledge, but the way I read it, if it’s a ‘97 then it’s 12163916, since all ‘97s have rear mount EBCM, and no export models. If it’s an early ‘98 non-export it’s 12163791, and an export early ‘98 would be 12189913 (export harnesses listed at the end of the item 6 column).
but hows an export harness different? im looking at getting 12189909 (i have a early 98 rear ABS no F45 manual) its not a export but i feel like it would be the same
They run the same as far as the car is concerned. Without an F45 computer in the trunk it is not going to load the settings into the ebcm and the harness works as normal. Feel free to cut and cap the unused F45 wires.
But the 12189909 is an (EXC F45, JAG) (EXPORT), which indicates it doesn’t have provisions for the rear mount ABS.
this is so confusing haha, in the manual it says JAG is in the rear by the looks of it but so do other EXC JAG models, able to clarify exactly what it means?
thanks for the help!
That is what I captured in my notes at the corvette 50th.
Ok....what does your RPO sticker indicate?
JAG isn't listed, it looks to be JAG just refers to the ABS module being mounted in the front, EXC JAG just seems to mean its mounted in the rear. 97 all were mounted in the rear and the RPO codes in the manual dont specify that its a EXC JAG then though it technically is. Still trying to figure out if p/n 12189909 will be a suitable replacement for 12163196 (manual transmission harness) both seem to be identical besides 12189909 is for European export (VD1) i cant see why their would be a difference but in saying that why have 2 different part numbers, any idea?
