Baer rear bump steer kit?
Old Jan 14, 2026 | 01:32 PM
Gotsboost's Avatar
Gotsboost
1st Gear
Default Baer rear bump steer kit?
I’m installing a Baer rear bump steer kit since I couldn’t source the factory rear ball joints (from what I understand they’re no longer made, and the few I found were extremely expensive).
My question is mainly about setup.
As I understand it, the kit works by using washers/spacers to raise or lower the pivot point to counter rear bump steer. I’m at stock ride height, and I honestly don’t have the experience (or desire) to pull the leaf spring and fully cycle the suspension with a bump steer gauge if I can avoid it.
Has anyone here installed the Baer kit at stock ride height and can share:
  • How many washers/spacers you started with
  • Any baseline setup that worked well
  • Whether you adjusted further after driving or alignment
I’m mainly looking for a good starting point that others have had success with, not chasing a race-only setup. Any real-world experience would be appreciated.
Thanks in advance.
