Vacuum hose routing
Old Jan 31, 2026 | 10:51 AM
daveshanda's Avatar
daveshanda
1st Gear
Default Vacuum hose routing
I have pulled the intake manifold on my 2002 C5 to replace the the oil pressure sensor. On the back of the manifold where the brake booster hose attaches there is a vacuum hose port that did not have hose attached to it does anyone have a diagram showing routing ?
Old Jan 31, 2026 | 11:02 AM
mmartinez's Avatar
mmartinez
That hose goes down to a vacuum canister underneath the battery, and then a small diameter hard plastic line from the canister is routed with a wire harness that heads into the interior. This vacuum line is used for the hvac system to control where the air is directed to, floor, vents, and defroster.
PS You might want to add a small length of vacuum hose to reconnect that line when you reinstall the intake, been there done that.
Old Feb 2, 2026 | 02:13 AM
oelarse's Avatar
oelarse
The vacuumline from intakemanifoil goes this vacuumtank as source (see bottom of picture)
To Vacuum hose routing
