Ignition Switch Issues
Old Feb 6, 2026 | 04:59 PM
Hello775's Avatar
Hello775
Cruising
Default Ignition Switch Issues
Hello,
I’ve been dealing with this problem since last summer. A shop recently traced it to the ignition switch and quoted me about $500 to replace it, so I decided to do it myself.
Today I installed a new ignition switch (GM Genuine Part from RockAuto). After installing it, the car started and idled perfectly, which was great. However, when I tried to drive to the gas station, the car cut out as soon as I pulled out of the parking spot. I’ve never had this happen before.
I checked the battery connections, and they seem fine. Now I’m wondering if I may have gotten a bad part.
For some background: last summer, I tried replacing the ignition switch with one from Amazon, which ended up being faulty. This time, I went with a “GM Genuine” part to avoid that issue. Visually, though, the new switch looks almost identical to the Amazon one, just with a different part number. It also looks different from the photo on RockAuto’s website; the one I received is all black and came in a GM Genuine box.
Before I start a return, I wanted to see what you all think. Does this sound like another bad ignition switch, or should I be looking somewhere else? Also, if you have recommendations for a truly reliable source for this part, I’d really appreciate it.
Thanks for any advice you have
Old Feb 6, 2026 | 06:02 PM
helga203's Avatar
helga203
If you don't know how to use a DVM meter you have to take it to a auto shop that specializes in electronic diagnostic not change parts but check wiring. If you do know how to; use Google on this subject. Tons off info.
And it doesnt matter where you buy electrons parts its a hit or miss. But diagnosed is a 100% and not guessing if the parts are good or bad.
Old Feb 6, 2026 | 06:44 PM
TheBac's Avatar
TheBac
In most cases, the all-black switches are not very good quality.
Hopefully you did not throw your oem switch away.
Follow this diy:
https://www.corvetteforum.com/forums...+switch+repair
It does work.
Old Feb 6, 2026 | 08:12 PM
mmartinez's Avatar
mmartinez
I don't belive the problem is the Ignition switch because the car starts and idles, it seems that the car is experiencing the 2mph fuel shutoff. Might have to take it to a auto electric shop to diagnose what it happening.
Old Feb 7, 2026 | 11:44 AM
Hello775's Avatar
Hello775
Cruising
I wish I had seen that post sooner. I think I tossed my old one, unfortunately. Really helpful, though, for diagnosing what's going on.
Old Feb 7, 2026 | 11:46 AM
Hello775's Avatar
Hello775
Cruising
You're right, I have a DVM meter, so I'll look into it. Just never used it before, so we'll see. If I can't find anything, I'll take it to a shop.
To Ignition Switch Issues
